Old 12-06-2020, 11:44 AM
allenga allenga is offline
Default Control Arm Rebuilds - Lever Family Racing
I just stumbled across this video of a rebuild. Looks like $90 a side plus parts. Have you heard of this company.
I can't afford Global West and Hotchkis tubular.
What do you think.
https://www.youtube.com/watch?v=x4Gx...ature=emb_logo
https://www.lever-family-racing.com/...m-a-body-64-72
Old 12-08-2020, 12:39 PM
ZeGermanHam's Avatar
It's $90 per side, plus parts, plus shipping both ways. In my view, replacing bushings and ball joints on GM A-body control arms is not rocket science and is not such a specialized task that it requires paying to ship them to someone who owns a hydraulic press. If you're going to go through the trouble of removing the control arms yourself anyway, just take them to a local mechanic and save yourself the costly added expense of shipping big heavy parts. I know he says that he blasts and powder coats them, but frankly, you can just use a wire wheel and hit them with some durable paint on your own. Doesn't sound like you're working with a show car, anyway.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 12-08-2020, 02:15 PM
JLMounce JLMounce is offline
I echo this sentiment. There's a lot of extra expense going on to ship these out when all you need is any basic mechanic who's shop includes a press.
There's no real need to blat the parts. Hit them with some heavy grit sand paper, knock it down after that with some red scotch bright and then use some chassis paint on them.
Put a set of ProForged .5" tall ball joints in the upper arms and a quality moog ball joint in the lowers, then select a good quality high durometer rubber bushing for the arms.
It may be "easier" to ship these out and get them sent back ready for install, but you'll save yourself some money and come back with an equal or better product if you take on some of this yourself and use a local service.
-Jason
1969 Pontiac Firebird
The Following User Says Thank You to JLMounce For This Useful Post:
Old 12-08-2020, 03:01 PM
Glenn is a member here. Got a long thread when he was building his dragster. Think he sold it when he got sick a while back. Don't think he's posted here since then.
https://forums.maxperformanceinc.com...d.php?t=644003
Clay
The Following User Says Thank You to "QUICK-SILVER" For This Useful Post:
Old 12-31-2020, 08:04 PM
Formula8's Avatar
Formula8 Formula8 is offline
Well if you are looking at global west control arms, I am assuming that you are okay with upgrading a bit if the cost is reasonable. With that in mind, Global West does offer their del-a-lum bushings to install into your factory control arms. Put in a tall ball joint and in my view, you would have a substantial improvement over stock without investing a ton of money.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
The Following User Says Thank You to Formula8 For This Useful Post:
Old 02-04-2021, 10:05 PM
Schurkey Schurkey is offline
Stock arms, Polyurethane bushings (no need for a press, DON'T remove the outer shells from the control arms) and new ball joints.
Worst part is removing the OEM rivets on the ball joints. Bushings get melted-out with a propane torch.. Easy.
And when you put them back on the vehicle, you don't need to torque the control arm bolts/nuts with the vehicle at normal ride height. You MUST have the control arms at normal ride height before torquing if you use rubber bushings.
Old 02-16-2021, 02:04 PM
grivera's Avatar
grivera grivera is offline
Last week I called 10 shops inquiring about R/R bushings on carried in factory control arms - none wanted to touch it. This is what has me considering the high expense of BMR arms.
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 02-16-2021, 02:13 PM
Dang, that's too bad. Though the BMR arms are nice.
I can walk a set of these in to probably 2 or 3 shops just in my town of about 100K people and have them back by the end of the day or the day after.
-Jason
Old 02-16-2021, 04:22 PM
grivera's Avatar
Wow- a couple shops actually told me not worth their time of off the car...at least they were honest
Will Rivera
Old 02-16-2021, 06:46 PM
Yet another reason to install Polyurethane bushings.
No press, no damage to the control arms, no special tooling. You need a propane torch + sandpaper/emery cloth, and a Scotchbrite pad.
And unlike rubber bushings, you don't have to torque the bolts with the suspension at normal ride height. So even the installation back into the chassis is easier.
Old 02-16-2021, 07:04 PM
grivera's Avatar
So the rubber bearing shells remain in good shape enough to put the poly bearings in place?
Will Rivera
Old 02-16-2021, 07:35 PM
Almost always. And if the outer shells are good, there's no reason to press them out of the control arm.
I've seen very few bushings that were worn so bad the outer shell had to be replaced. It can happen, though. Generally a matter of the rubber is GONE, so the inner steel sleeve is banging against the outer steel shell. I suppose there could be massive corrosion that would make the shells unusable, but I've never actually seen that.
My K1500 had the inner sleeves corroded to death, but the outer shells were fine.
