04-06 Interior Tech Everything that goes on inside the GTO. Dash related, Upholstery related, Console related, etc. |
06-27-2011, 05:11 PM
Sticky Ignition cylinder
My 06 is having a problem with the ignition cylinder, when going from accy to the start position it gets kinda tough to turn like its binding, sprayed some white lithium grease in it and it loosens up for a little while then gets tough to turn again, anyone else having or had this problem? need to replace it? thanks for any help.
1969 Judge, Matador Red, Black, RAIII 4Spd, Owned 33years
1974 LeMans GT Honduras Maroon, 3 speed stick 350 2brl.
1963 Catalina 389 Black with Burgandy Ventura interior SOLD
1970 GTO Pepper Green 400 YS auto Factory A/C 56K orig miles
06-27-2011, 05:21 PM
You need to go on LS1GTO.com and the ignition lock problem was covered in depth. When it starts sticking they said you need to take action or it will lock up completely and then you'll have a bigger problem as it needs to turn to be removed and repaired. I read about it awhile ago, but mines doing fine right now so I'm not to worried at this point. Good luck on your repairs..................
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
06-28-2011, 05:43 PM
Thanks guys, gonna order the new one and tackle it.
07-06-2011, 04:10 PM
Tried the dremel trick and it is working like a champ, re lubed it with some white lithium and even with the car baking in the sun all day the key turns like new.
