https://www.iimuch.com/collections/f...ts/fuelvent2dm I don't know if it is really a separator or not. Problem is I can not find a place to install this (that I like) that is as high as the filler neck. Rembember, my car is actually an el camino and I dont want to install it in the bed if I can help it. Short term I am going to install a checkball type of vent inside the filler cap of the car right next to the fill tube..
440, E-heads, Performer RPM, holley sniper, "stump puller" cam, 3.42 gears, 3540 lbs |
Those are nice, a little expensive, but very nice. You can pretty much install it anywhere, and run lines to the tank vent, just as long as the lines don't capture/hold fuel.
Remind me, the tank is in the rear behind the diff hump on those? What's the OE vent config? You could do a bracket on the frame rail, mount the separator you got there, on an L bracket. If you mount it to the front or rear of the peak of the frame diff hump, the tire will clear it that way. It would be better to mount it on the inside of the frame rail, would be safer, you pick up a rock in the tread and spin the tires, it could spark. Maybe take a pic of it under there and post, sure you will get a few suggestions here. .
I prefer 1/2" line feed and return, and running the length of the car. Best way to do it, supports upgrades later, trouble free, and never look back. |
I will take some pictures.
66 el camino only a vented cap and a hose "tapped" off of the filler tube that goes back to the tank.. Yes - expensive. It comes with an L-bracket in the config I bought. Another thought I have is to run a hose from the tank up to the filler neck and then back down to the vent (II MUCH) wherever I can mount it with it being at least above the tank (i.e. so it can't create a siphon.) This up and down idea with the vent line would essentially be similar to what I saw on another post on this website. I think it was a 68 pontiac that has a metal vent tube that is connected to a hose that come up from the gas tank into the trunk then turns back down through the trunk and vents under the car. If I can find the picture of it I can post it. I also have a 3/8" inline one way check valve that can go inside the vent line for rollover protection, and presumably to help prevent fuel from coming up the line in normal operation.
440, E-heads, Performer RPM, holley sniper, "stump puller" cam, 3.42 gears, 3540 lbs Last edited by 455'73inElCamino; 07-03-2019 at 04:15 PM. Reason: added comment about pontiac trunk vent. |
I'm not saying right or wrong. Just posting what I have working on my Sniper. External pump( came with the kit), stock 3/8" hard line feed, 5/16" return line. I went with the everything in the box kit because I didn't want to have to chase around ordering things from different places. Haven't had any starvation issues with it yet but then I haven't pushed it real hard yet either. I do have 72psi running fuel pressure instead of the 59.5 that they say the regulator is set at. I assume it's because of the slightly smaller return line. The Holley tech said it should be fine to 90psi with out issue. The pump isn't noisey. The only time I hear it is when it initially primes. I don't know if it gets hot. Never checked it but it is exposed to free flowing air so I doubt it does. At some point I may swap out to an EFI tank but it probably won't be until I have issues with what's on there now. Have about one year on the present setup. So far so good.
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
I have pictures that I will try to post tonight. I have not been able to get this website to work on my computer until today. I am guessing it was down for July 4th weekend "maintenance".
I am going to have to redo the pictures.
I did talk to Tanks Inc. again and he did say that I can run the pump vent hose to the vent tube at the top of the fuel filler tube, and the tank vent to the actual vent supplied, which should be at the highest point possible. In other words, these two vent hoses do not need to be tied together. Also, he said that this can be done while using a NON vented gas cap. It is my thought that the tube/hose going to the vent can be made to go to a much higher point than the vent itself and then come back down to where the vent actually gets mounted. I believe this is consistent with the vent tube that is found going up into and then back down out of the trunk on GM cars. Of course the vent still should be as high as possible and there should be no sags in the vent line where fuel can accumulate. Anyone see why the vent hose should not be run as high as possible? Given that the vent is going to be higher than the tank there should be no danger of a syphon effect.
Finally, I have the two vent lines in. Again, I will get the pictures done this week.
It is different in many ways that what I originally intended but I think this will work.;
