Old 01-02-2024, 08:27 PM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
I'm asking a friend who has an authentic 1970 gto ram air 3 engine if he has heat flaps . these are 5 bolt holes. 2 on each end , one in the middle if i recall right. guess we are going back and forth on this one!! at least all agree it's a 67 and 69 mis match pair. lol
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
Old 01-02-2024, 08:31 PM
Yes, I am wrong.
I forgot that the new 69 GP was based on a extended A body frame.
Old 01-03-2024, 04:42 AM
Kenth's Avatar
Kenth Kenth is offline
This may help some: (Thanks to H.O. Racing)
Name:	D-port manifolds.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-05-2024, 05:05 PM
kyle_blake's Avatar
That is really cool that list. Undecided what to do with mine, i see they are about what $360 US for a pair new if they were in stock.
https://butlerperformance.com/i-3010...tegory:1389521
Old 01-07-2024, 01:29 PM
RARE has the performance ones in stock for $550:
https://www.ramairrestoration.com/po...poncho-v8.html
That's still less than a pair of headers.
Depending on your intended build manifolds are a nice option for a number of reasons.
Obviously, if you plan to lean more towards the performance side, the RARE manifolds would be a better choice.
You could sell the set you have to reduce the overall cost of replacements.
Old 01-07-2024, 03:22 PM
Originally Posted by 242177P View Post
They're definitely reproductions (note no heat flapper)
1968 was the last year for the heat flapper.
1969-up did not use them. Not in stock manifolds or ram-air or long branch.
The Following User Says Thank You to Joe's Garage For This Useful Post:
Old 01-07-2024, 05:12 PM
NeighborsComplaint's Avatar
Why are you concerned over the mismatched (year) exhaust manifolds? As long as they are both RA manifolds with the same size outlets, just have them blasted, coated and put them back on. When you open the hood, they're not going to look any different than numbers matching or reproductions. Save your money for machine work and internal parts.
Triple Black 1971 GTO
The Following 2 Users Say Thank You to NeighborsComplaint For This Useful Post:
Old 01-07-2024, 05:44 PM
Can think of exactly one type/style of reproduction A-body RamAir manifolds that look so close to originals that one would have to have them off & in one's hands to note the difference.
The more I read posts in the Street Section... hard to tell if PY has become more of a joke than Pontiac FakeBook sites.
