#41
One quick follow-up question and I'll end the hijack... Stock 1969 GTO nodular LS rear...
8.2 or 8.5? Cone or clutch?
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 02-07-2024 at 05:10 PM. |
#42
8.2 cone type.
The Following User Says Thank You to b-man For This Useful Post: | ||
#43
Thanks Bart!
Greg Reid Palmetto, Georgia |
#44
If your putting power to an 8.2 in an A body you probably should have something like a QA1 anti hop bar to make the rear end dig in and not have wheel hop. Wheel hop with a stock suspension A body seems to kill the 8.2 as much as anything. I don’t have a qA1 setup, we created ours, but my center control arms are raised up on the rear end like a QA 1 set up. It made a big difference, eliminated wheel hop completely using a 30” tall drag slick.
#45
We put a Moser 12 bolt in my buddy’s 69 gto not to long ago. The rear came from JD we just ordered new backing plates with brakes and had him install them before he installed axles so we didn’t have to redo it. With brakes it was less that $3500.00. It is far better than any rebuilt stock 12 bolt you’re going to find. With that said take a better look at your 10 bolt it might be a nodular center section. The 10 we pulled from his car is a N center section with 3.55 gears. Now it sits on jackstands in the corner. The purestock car he races has a 8.2 with a good posi unit and aftermarket axles it’s been getting pounded on for 20+ years now still going strong I’m talking hundreds of track passes.
#46
You're lucky that he's right around the corner from you. The cost of shipping from OH to CA isn't cheap - about $425. Even still, it might come up less than a Moser which is pricing out around $4600 after tax and shipping ($450). If I wanted the rear powder coated it would push me close to $5k. Quote:
I went ahead an ordered a T/A girdle for now while I make up my mind on a new setup.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
#47
Aren't 12 bolts still a C clip axle? Do the aftermarket units come with bolt in ends?
Ive never understood why anyone would pay Moser aftermarket prices for a 12 bolt, when a 9 inch is basically the same price. If you are sourcing locally and trying to stay cheap then a C clip 8.5, 12 bolt or 8.8 make more sense.
#48
Factory 12 bolts are c-clip. The aftermarket 12 bolts have the option of bolt in or c-clip.
#49
There is an absolute 0% chance I would pay $2000+ dollars for a C clip axle. And I say that as a guy who regularly defends 8.5s as a budget option.
#50
With what those moser 12 bolts cost, I'd take a long hard look at a nicely built 9 inch from a place like quick performance.
1968 - Pontiac GTO |
#51
curious question, hope not to move convo away from op, i was thinking eaton posi unit went up $250 since 2019, richmond gears, then new after market axles, moser i think ? my bop corp n differential with that plate on back would make it capable of handling 500-600 hp ?
am i out to lunch? wont be any sticky tire launches
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane |
#52
For what you’re doing sounds like what you have is fine but I know upgrades are fun.
The Following User Says Thank You to grandam1979 For This Useful Post: | ||
#53
https://www.quickperformance.com/9-F...7_p_20385.html
All the bells and whistles, $2800 with 3.25 gears and true trac. This is what I did and it's awesome. I've also got a 3.89 detroit locker 3rd member, I can swap them for strip or street.
I could explain all this to the girl at the parts store, but she'd probably call the asylum. White '67 LeMans 407/TH350/Ford 3.89... RIP Red '67 LeMans. 407/TH400/Ford 3.25 Last edited by chiphead; 02-08-2024 at 01:16 PM. |
The Following User Says Thank You to chiphead For This Useful Post: | ||
#54
#56
Takes me about 2-3 hours. Gotta get it on jackstands, pull the tires, axles, exhaust, driveshaft, drain diff oil, remove 3rd member bolts and those little copper washers, pry the 3rd member loose, wrestle it out, wrestle the other one back up on a jack, shove it in place. Installation is the reverse of removal....
It's not a cakewalk, but still easier than having the gears set up in a GM rear end.
#57
To me, that 9 inch from Quick Performance looks like the way to go. I went this route: https://www.strangeengineering.net/p...g-mounts.html/ Which is great, but a 3.54 gear is the tallest gear you can get, and you still need a full gear setup to swap ratios. With that 9 inch, you get a very strong rear, easy gear changes, and a wide range of available ratios. When I put my S60 in I got 3.54 gears because I had a standard wide ratio muncie. Now I have an ultrawide muncie and first gear is almost 3:1. If I had a 9" I'd swap the 3rd member for a 3.08 ratio, but not available for a Dana 60. I'd have to think that 12 bolt looked awfully pretty under my car to go that route instead of the 9 inch!!! |
#58
Eaton makes a 30 spline 8.5 carrier and anyone can make 30 spline 10 bolt axles. I have Dutchman in the 81 and Moser in the 78. Dutchman could make a longer brake pilot than Moser would to locate a rear disc and hubcentric wheels. Moser we had to tack and extension on.
Moser and most others weld on bolt in bearing retainers-I added them to a factory 12 bolt in the IA Camaro with a 33 spline spool as you can but them separate. Strange has a "Street C Clip Eliminator that use the same taper bearings 3.150 OD they use on weld ons
#59
How do you distinguish the quoted Cutlass 8.5 from a Chevy 8.2, do you have a rear cover or bolt to bolt dimension or some other distinguishing feature?
1972 GTO 468 2 Bolt Main w/Eagle rotating assy SD Ported 295 KRE D Ports 10.8 CR OF Hydraulic roller w/ 1.65 stainless rockers Performer RPM Intake Holley 3310 780 Vacuum Secondary TH400 with 10" Continental Convertor 8.2 BOP 4 pinion 10 Bolt with 3.36 gears 11.428/118.95/1.618 |
#60
I would say if you can get good price on a 8.5 with bolt in axles up grade at least to good 28 splines or jump to a 30 spline carrier and axles and it will be as good as a 12 bolt for what you are doing.
