Anyone know if anyone makes dropped spindles for a 1969 big car? (Catalina)
So if none are available, can they be custom made? Or is it too expensive?
I'm not aware of any dropped spindles available for Pontiac big cars. You could check with Fatman Fabrications, they make dropped spindles for a lot of cars and I believe they will do custom jobs, but it probably won't be cheap...even the ones they have in stock are in the range of $400/set. Depending on how much you want to lower your car you may want to consider shorter springs or maybe one of the airbag suspension companies like Air Ride Technology.
http://www.fatmanfab.com/05page17.htm http://www.ridetech.com/ |
I have not had any luck with 'the fat man', but you may get lucky...
These people should be able to make them for you... http://www.superiorspindles.com
