Starting Over
Ok guys, the 400 in the bird laid down on me tonight. Had to have her towed home. Something broke loose and it locked up. Hoping to be able to save the crank, block, heads, and cam.
My plans are to build a strong street motor that can be driven a lot. I will go to the track but not very often and just for fun. I'm not sure what the heads are yet as far as an I.D. number. I have a Holley 750dp an Edlebrock performer intake. I am open to any suggestions on what pistons, rods, rockers, and a cam if the one I have isn't what I need. I know the cam is aftermarket I'm just not sure what it is. I will be on a budget and I'm very new at this so speak in English if you can......I'm excited to get the motor build like I want it. |
How much money do you want to spend?
Figure $10-$15 per horsepower for a new build.
Well I'm not sure how much it will take but I don't have $10,000 to spend as bad as I'd like to.
What heads are the good 400 heads? I'm not sure which one's I have but I'd like to know when I look at them. |
Stock heads or after market. 16 are good for stock. Same with the 48. Hell even 6x-4 are good. As for after market you have a lot of choices. It comes down to what the goal of the car is. Be honest on hp goals and what you really want it to be. There is a lot of good info on this board you just have to search through and plan it out.
Also read the "Tech thread archive sticky" at the top of the street section. There is a bunch of good info there. After reading this stuff and nailing down your specific goals, you will know which questions to ask. http://forums.maxperformanceinc.com/...d.php?t=644938 |
Why not just buy a good used motor...1500 to 2500 will get you a decent long block...put your carb etc on and go
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright" |
Budget and power level?
We all love to spend others peoples money don't we. You figure a stock rebuild from Spotts cost about 4800 bucks, soup to nuts, cam broke in, and set up on his stand. I spent about 7500 bucks starting from scratch on my last full build. Hopefully you can reuse some of your old stuff. If you don't have an extra block and parts laying around you'd be one of the few that don't. Stock up. Hope you get her figured out.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Ok, now I'm kicking around the idea of just going with a 455. Buy a good block spend a little money on some good heads and use my carb, cam, intake, etc. I mean my block is probably shot, gushing water last night.
The heads on this 400 say 4x?? not sure if they are good or not.....I'd probably go with an aftermarket head if these aren't very good. Keep the info coming it helps more than you know. |
The 4x heads can be made to run good. I ran high 13's with a 74 400, stock 4x's, summit cam, forged piston trw rebuid kit, perf rpm intake, 650 dp, hooker super comp headers, 2 1/2 inch ex with flowmasters, st 10 trans, and 3.36 gear out back. I'm no engine builder but figure out what you do yourself, do your research, and plan it out. Buy the best parts you can reallistically afford. Most importantly find a good machinist, you could buy awesome parts but they ain't nothin if its not machined right. A 455 is awesome choice they make horsepower almost by accident and gobs of useable torque for the street.
Butler has assembled stroker short blocks for $4400, all choice selected parts. That's hard to beat...
Short Blocks 461-474 cu. in. Assembled Performance prepped 400 (or 455 block/ additional cost) -bead blasted and magnafluxed, sonic tested, completely deburred, bored and honed with torque plate - line honed with ARP main studs, deck squared, cam bearings,and brass freeze plugs installed New Crank (4.250 Stroke) Eagle 6.800" Rods Ross Pistons (Bore 4.155 - 4.181 - 4.211) 430 grams - nitrous safe Ferrea Pins File Fitted Rings Bearings FM/CL77 High Volume Oil Pump HD Oil Pump Shaft Complete Gasket Set Balanced Internally Lifter Bore Holes Tapped for Restrictors(if neccessary) All parts and block thorughly cleaned, inspected, and blueprinted before assembly . Comes With Complete Blueprint and Build Sheet Assembled Short Block (461-467 cu. in.) w/ Cast Crank $3,995.00 Assembled Short Block (461-467 cu. in.) w/ 4340 Forged Crank $4,395.00 .
Wow, that is hard to beat!!
Yeah, but Firebirdfirerfighter said he was new, and wanted one build like he wanted it. No doubt though, $3400 for a forged crank stroker with all the machine work done is inexepensive for sure.
Looking at a 71 455 with 66 heads, complete but needs built. Probably going to try and get this one if it works out. Use the block crank and heads, my cam, carb, headers, and intake and see what happens. Keep the suggestions coming I really appreciated it.
Never reuse an old cam on a new build, unless maybe it's a low-mile roller. .
I've corresponded with a few builders to this point, and if I was doing it today, I would send my engine to Butler. Good advice, not running other builders down, very flexible and willing to discuss the combination.
I have a builder. A good family friend that is very good at it. I found a 455 complete from intake to pan for a very good price. We are going to take it down and see where to go from here. I'm going to use forged rods and pistons, the crank that's in it, get a new cam, and use my intake and carb. Now I just have to get a second mortgage to pay for it all!!
Thanks for the advice, it has helped. I'm sure I will have more questions. |
