WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 2008-09 G8 owners > G8 Electrical Tech
G8 Electrical Tech Common electrical problems that go on in the G8.
Old 09-19-2013, 03:40 PM
1969GiPper 1969GiPper is offline
Default RKE Transmitter (FOB) Pushbutton Cover Came Off
For some time I've been noticing that the plastic (rubber) pushbutton that covers the switches inside my 2009 G8 key fob has been getting soft and bubbling up. A few days ago it finally fell off. I tried to reinstall it but had no luck because it is so badly deformed. Note: This is on the fob with the "flip out key". Not the fob with the rigid key. First dealer I talked to said that I have to buy the whole transmitter, plus have the new one programmed to match the car. So I checked with a buddy of mine at GM and he found out that I can buy just the part I need. The GM part number for just the pushbutton cover and the plastic frame around it is 92245050 and it costs $9.60 plus sales tax. GM calls it a "pushbutton". To replace the part just follow the procedure for replacing the battery. Once you have to old pushbutton off simply swap the switch board from the old pushbutton to the new one. Then reassemble the fob. No need to reprogram anything.
Old 09-24-2013, 05:41 PM
eric_cspan's Avatar
eric_cspan eric_cspan is offline
Administrator
Yup. The G8 key fobs are sold in three separate pieces. You can buy:
1. Just the transmitter
2. The case with flip key
3. Just the remote button. ( very common with these cars to crack and need replacement.)
"LIKE" Max Performance on Facebook!
"LIKE" Cold Case Radiators on Facebook!
"LIKE" GTOG8TA.COM on Facebook!
Old 09-25-2013, 01:13 PM
Region Warrior's Avatar
Ya the parts catalog is messed up.
If they went to the illustration in 10.485 1st, it says not serviced separately.
But it is listed in the 2.187 illustration and non illustration parts group.
Old 10-28-2013, 06:08 PM
AfroditaNam AfroditaNam is offline
Default Anybody can help me?
I need to contact with Administrator
Do know anybody him contacts?
Old 10-29-2013, 11:16 AM
eric_cspan's Avatar
Administrator
you can send me a PM
Featured Vendors
Advertising Info
