WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 1993-02 Firebird/Trans Am Owners > 93-02 Engine Tech
93-02 Engine Tech LT1 and LS1 motor heads unite!
Old 12-19-2013, 06:44 PM
cballweg cballweg is offline
Default HELP!How Do I remove LS1 Water Pump Pulley?
Is there a tool to remove the water pump pulley on an LS1 Trans Am and another tool to press a pulley back on?They are pressed on.I have a billet pulley I want to install.Thanks for any help.
1969 Matador Red GTO Judge,1999 Ram Air Trans Am,1998 Daytona Pace Car Grand Prix,1959 Bonneville,2004 GXP Bonneville.
Old 12-24-2013, 11:00 PM
I found out to remove pulley you can weld a nut on the end of the pulley and put a bolt in the nut to pull it off the water pump shaft.The only thing I can think of to install new pulley on would be to drill a hole into water pump shaft and tap it to pull the new pulley back on but dont know if you can drill it or how deep to go into shaft.The only other way would be to remove water pump and press the pulley on with a press but Id like to not have to remove the water pump.If anyone else has any ideas please let me know.thanks
Featured Vendors
Advertising Info
