Exhaust manifold rust removal before paint?
What would be the best way to de-rust my RA3 manifolds so I can paint them for my next build?
Molasses? Oxalic acid? E-tank?
1969 GTO hard top ~ Std bore 400, '70-RA3 block, 670 heads, Bal. & Blue... M22, 12-bolt w/3:55s |
Soak it in distilled white vinegar and water over night. The rust will turn black and flake off. A once over with a wire brush will take off the rest.
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track. |
Was thinking vinegar too. My concern is rust, and chemicals in the remover, "bleeding" back out of the porous iron and through the hot paint.
A shot trip to the blast cabinet and a short bath in WD-40 Rust Soak.
Don't paint them, have them coated. |
Exactly, media blast and coat with POR-15 manifold paint, or have them coated. Coating costs more, but will probably last longer. I've had real good luck with the manifold paint though and it lasts a long time. Can touch it up too.
Replace the studs, tap/chase the threads, and use anti-seize. Use anti-seize the entire length of the bolts and bolt heads when installing on the engine too. Tap/chase the head threads too. EDIT: Eastwood high temp coating works well too. You can chemically remove the rust, but you have to etch it after, and before you paint. That ends up getting pretty close to the cost of blasting, so it makes sense to blast. .
Thanks. Sounds like a trip through my local shop's steel shot blaster is in order.
If you use steel shot, it will make the surface smoother and won't look OE, if that concerns you or not. Will make it denser, which will help prevent cracking, I think.
Harbor freight sells gallon jugs of Evaporust that stuff works slick. Doesn't leave a film after the metal is cleaned. I used to use phosphoric acid but like the Evaporust much better. If you don't have a blasting cabinet this is the way to go for small parts.
Electrolysis. I use a tall trash can and put the (pre-scrubbed) manifold in. Use tap water and fill over the top of the manifold and include a few tablespoons of Borax 20 Mule Team brand (Walmart), Using a 10 amp battery charger hook up the negative end to the manifold and the positive end to a three foot long piece of flat steel (1.5"x3') found at the hardware store. Put the charger on manual and let sit for 24 hours. If the piece has a ton of rust you'll need to change the water out at least once if not twice to get the majority of it off. Refill with new tap water and recharge for another 24 hours. I use Eastwood's Manifold Gray formula to coat them.
ETA: This process is messy but it does not remove material and it also gets the rust off from the inside of the manifold.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
I use my blasting cabinet full of glass bead. They come out looking brandy new, almost a shame to cover it up with a coating.
I also agree about the Evaporust. Good stuff. |
I blasted mine with coal slag in a blasting cabinet and painted them with VHT Flameproof paint in the cast iron color (part #SP998). After 2 years, they look pretty much like they did when I painted them, with only very slight discoloration. The curing process is very important with VHT. If you follow the directions closely, the finish will last many years and is a lot less expensive than coating.
This is what VHT says on their website for curing the manifolds if they are off the vehicle. I did mine in the oven and could only get to 550 degrees, but it didn't seem to make a difference. Paint must be completely dry before curing Heat to 250°F (121°C) for 30 minutes Cool for 30 minutes Heat to 400°F (204°C) for 30 minutes Cool for 30 minutes Heat to 650°F (343°C ) for 30 minutes Caution: Do not exceed the temperature of the least heat tolerant component or the base metal
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds. |
I've heard really good things about this stuff and I'll probably try it... http://www.amazon.com/Calyx-Cast-Exh.../dp/B003D0R426
Greg Reid Palmetto, Georgia |
I had a pair of heads stripped, years ago. It's a reverse plating process. Took all the rust out of, off of them, looked like fresh cast iron when I got them back.
They advertised their business as metal stripping. Don't know of too many places that perform such services...
After some thinking an e-tank will be in my future. Lots of other pieces I can de-rust, and no worries about possible solvent residuals. Now to make some calls about used graphite EDM rods for the anodes.
Yep, mine were too. Only driven on sunny days and wouldn't come out in the spring until we had a few heavy rain showers to wash the salt off the roads. Yet even the $500 Jet Hot coatings I had on headers would only last 4-5 years before pitting started. Stuff out of the can might go 2 years tops.
It's those 90% humidity Cincinnati days with 70 degree dew points. The moisture in the air is so thick you may as well be driving in the rain, lol. Out here in Arizona, don't have that problem. I'm not so sure I could even physically adjust to it myself if I had to go back. |
