Old 06-13-2015, 07:25 PM
devauxmidwest's Avatar
devauxmidwest devauxmidwest is offline
Default 65-68 RH Remote Matching Mirror
I'm looking for the right hand mirror that matches the left hand remote mirror.
Old 06-14-2015, 01:10 AM
70ra455's Avatar
70ra455 70ra455 is offline
Was that an option? I don't see it in the brochure?
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console
1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats
2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather
Old 06-14-2015, 01:26 AM
Steve Barcak's Avatar
do not believe it was offered until the mid 1970s
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 06-14-2015, 11:40 AM
BOB VIDAN BOB VIDAN is offline
The 65 - 68 RH mirror does match the LH remote but the RH is fixed.
Practicing social distancing for 65+ years
Old 06-14-2015, 12:09 PM
Bob,
That's the one, the fixed RH mirror that matches the 65-68 LH remote mirror.
Old 10-14-2015, 02:04 AM
Bonn66 Bonn66 is offline
Default RH Remote Mirror '66
Hi, the fixed RH mirrors exist, but are impossible to find as very few were ordered as an option from factory.
I just finished building one from a factory LH remote mirror:
Stripped and polished it.
Then from a piece of 32mm Alum tubing I cut the required spacer to turn angle from LH to RH.
This was harder than it looks as just a straight angle cut made the bottom of mirror hit against the base.
So had to be angled in and up to clear base plate.
When I was happy with the angle, I sent that off for Chrome Plating.
I filled base piece and spacer with metal putty.
When they had dried together I drilled out enough room for remote cables and attaching bolt.
Using an M4 x 90mm Stainless Steel Allen bolt, I reversed a wing nut and moulded that into the mirror housing for a secure anchor point.
Next was the point of no return, a 20mm hole saw into Bonne’s door. 4x drill holes required to mount mirror!!
Mirror on and looking good. Next step, drill hole for Remote in door trim..
Done, looks like factory, except they never did a RH remote from factory in ‘66 (but should have).
cheers
paul
Name:	5. Connected to base, filled with steel putty.jpg
ID:	410286   Click image for larger version
Name:	6. M4 x 90mm SS allen bolt with nut moulded into housing.jpg
ID:	410287   Click image for larger version
Name:	7. Dry run, all together.jpg
ID:	410288   Click image for larger version
Name:	10. Door trim drilled and remote fitted.jpg
ID:	410289   Click image for larger version
Old 10-14-2015, 07:55 AM
lugnutx2 lugnutx2 is offline
Very nice work!
Old 10-14-2015, 09:42 PM
stevep's Avatar
stevep stevep is offline
My 64 Brougham had one. I even lent the mirror to Steve Ames to try to repop it but it didn't happen.
I did buy an NOS one 25 years ago at a POCI convention.
Old 11-17-2015, 04:08 PM
66 Wagon's Avatar
66 Wagon 66 Wagon is offline
There is a right hand NOS mirror for sale on eBay right now. I think this is the one, even if it's says "64-68 GTO".
I would like one on my car, to match the left remote mirror, but the price, $1,750.00, is way too much for me.
Link to eBay: http://www.ebay.com/itm/1964-1968-Po...-/131654014975
Pictures of the mirror
http://forums.maxperformanceinc.com/forums/image.php?type=sigpic&userid=169941&dateline=15132  72224
66 Bonneville 4-door Hardtop - Sold - But it has its own thread here
66 Bonneville Wagon - Sold
63 Grand Prix - Sold
Old 11-17-2015, 05:28 PM
olmanwinter olmanwinter is offline
You don't want anything to do with that eBay seller. I have seen tons of bad press about them.
Old 11-17-2015, 09:53 PM
68Prix's Avatar
68Prix 68Prix is offline
I would like one also. I know they are rare, to bad the aftermarket doesn't make one.
Old 11-17-2015, 10:23 PM
70ra455's Avatar
One sold on ebay a few months ago for $125 and it was in similar condition.
And stop grousing about $1750 ... they've included shipping what else do you want?
Old 11-17-2015, 10:26 PM
Wow, $125 for a RH orig mirror, missed that one...
Still, didn't take too long to knock up my Remote RH mirror from an orig LH.
