radial tire duck walk
does anyone have any help what to do
Replace the tire.
Sounds like a separated belt. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
If the tires are all the same age, then replace ALL the tires
If one has gone bad, the others will not be far behind.
From experience. Unless you enjoy seeing your tire guy every month....... Good luck! |
all for are new only 10 passes
Even new may have a problem. I would take them somewhere and check the spin balance.
Not exaulty what you mean by "duck walk". I assume car moving around. May not be just tires. At your speeds aero and alignment comes into play. A good savy front end man might help out. A good four wheel " race orientated " alignment may help. It did mine.
Might consider a chin spoiler to keep air from under car. I also blocked off my grille opening to keep air out under hood. Talk at ya later.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Did you mean a "waddle" at low speed? Like in a parking lot?
K
No Kieth. I talked to him last night. He's referring to top end problem of car moving around. He's running radial slicks on his low 9 second 63 Tempest.
My radial slicks are very stable due to being run at a higher PSI. (17-20 PSI) I doubt it's the radial slicks causing the instability. Sounds like Troy is on track.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
On my near new drag radials my car was rocking pretty darn hard about 60 ft out.
One of the tires had a large amount of weight to get it balanced, I think the tire may have spun on the wheel and made the balance really bad. I pulled the double adjustable shocks off and removed the springs and found one shock was way easier the compress. Adjusted the soft shock till it felt almost like the other and it helped a bunch but the rear still wobbles around. But sometimes its worse then others but this has been on the street. |
K
K
Is there a picture of the car ??
x2.
I was going to ask that, too. K
I had a similar problem with DRs at the top end, for me it was too low a psi. It got kinda scary at the big end. I actually did better times with more psi too.
4-links eat right rear shocks, bags help. But on my '71 a-body, the right rear shock lasts about half the miles of what the left one does. .
This is a picture from this past Sunday. Any help appreciated!
well damn I cant see if it has a wing or spoiler out back but at that speed it prob should --- ask me how I know lol I suspect it is lifting the ass end up at speed and the tires are getting loose on ya.
I talked to Randy Peer last night as well. He sent the Hoosier tires back to Summit, they gave him a new set, still does the same thing at the 1/8th mile (115 mph). Had to abort the run. 19 psi. ??
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Granted my 10 second runs are not the same, but my 2 sets of Hoosier radial slicks as well as DR were much more stable at speed than my bias slicks were even running 12s.
Alot of the quicker Street cars over here get 'radial rock' at the top end,usually around 170mph, doesn't seem to be a cure for it.
