WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 1993-02 Firebird/Trans Am Owners > 93-02 Engine Tech
93-02 Engine Tech LT1 and LS1 motor heads unite!
Old 03-08-2017, 04:37 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Default 99 3.8 swap into a '02?
Hey guys so here's my question.
I got a totaled 99 Grand Prix GT coupe with a naturally aspirated 3.8 that is a good motor. And has a good new transmission.
I'm looking at a perfectly good 2002 Grand Prix GTP with supercharged 3.8 that has a rod knocking in it.
Do you think I could put the good 1999 3.8 into the 2002 and put the good supercharger on the 1999 3.8?
And put the new trans from the 99 into the 2002?
Best I can tell is the 1999 3.8 is a 9.5:1 motor and the 2002. Supercharged motor is a 8:5:1 motor.....
But do you guys think it will work?
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.854@160.12 in Brainerd MN 7/2024
Old 09-15-2017, 08:11 PM
AWdies's Avatar
AWdies AWdies is offline
Seeing how old this thread is, I don't know if this idea is still pertinent, but for anyone else that may be considering doing this, there is such a thing as "top-swapping" a supercharged 3.8's heads, intake, harmonic balancer, and other related items onto an otherwise NA 3.8. It's possible, and because of the different pistons in the NA as opposed to the supercharged motor, it will have a higher CR than a stock GTP, and will make slightly more power.
Here's a link to doing just that from the grandprixforums, of which I am also a member!
http://www.grandprixforums.net/threa...s-of-3800-Info
Lots of great info there.
1971 Triple Black GT-37: Restoring!
Featured Vendors
Advertising Info
