WELCOME!
Go Back   PY Online Forums - Bringing the Pontiac Hobby Together > PY Welcomes 2008-09 G8 owners > G8 Exterior Tech
G8 Exterior Tech hoods, spoilers, carbon fiber trim, etc
Old 03-21-2020, 12:59 PM
shook1's Avatar
shook1 shook1 is offline
Default door key spins
My key spins without unlocking the door on my 09 G8 GT. I thought it was just something disconnected, and asked the mechanic to check it out while he had my car in for a brake job. The mechanic said the key lock mechanism is either bad, or needs a locksmith. Perhaps a previous owner changed the ignition and key, but not the door lock. It appears to be a common problem with the Pontiac G8, according to the locksmith he called.
My question is, does anyone have a remedy for fixing or changing this lock without spending hundreds for a locksmith or Dealer?
My key fob works fine, but I am afraid one day the car battery will die, and I'll be locked out. There is no way to charge the battery, which is mounted in the trunk, if I cannot unlock the car. Also, the fob could get wet or damaged, leaving me stranded in a parking lot. The other doors and trunk do not have key locks. Why is GM eliminating key locks?
Old 12-22-2022, 02:32 AM
Trevor78 Trevor78 is offline
It's meant to, if it doesn't recognise the key, or is the wrong key, it will spin. There can be a few reasons why, good or bad. But it's designed to.
The Following User Says Thank You to Trevor78 For This Useful Post:
Featured Vendors
Advertising Info
