OER Rally Gauge Conversion kit
Does anyone have any experience with this OER Rally Gauge set up where one reuses original lense and needles? If so- is it if decent quality and worthy conversion?
https://www.ebay.com/itm/133192838467
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
I called Ames and sales rep said I would need the rally gauge sending units (oil/coolant) to make these work. They had no opinion on quality.
I'm not familiar with OER gauges, but usually when doing a conversion like that (I've done a couple) they require a different circuit board (where applicable) and a different wire harness as well as the sending units you mentioned.
Usually I've found it's much easier to buy what they call a "conversion kit". Several places sell them, and they come with a wire harness, with instructions to change pin outs if needed, circuit board, gauges and any sending units needed. The last one I bought through Hitechclassics when I was doing a Chevrolet. Great quality, excellent service, and worked perfectly. Came with everything needed for the swap start to finish. The conversion can start to get expensive rather quickly though. I've never had a kit where I had to swap in the old needles and stuff. Not sure why they wouldn't just supply you with all new workings. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
Thanks - it's odd cause this one says it includes the circuit board and specifically designed to work in place of the idiot light set-up. However, I'm not willing to be the guinea pig on it - was hoping to reach one of the six purchaser from Ames - yep, only six sold.
From listing: "Rally gauge conversion kit for 1969 Firebird originally equipped with factory warning lights. This cluster is specifically designed to convert factory idiot lights to rally gauges. Kit includes the housing, rally gauges, rally speedometer face, and a brand new printed circuit board. The vehicle's factory speedometer movement, lens, and inner bezel are reused. This is a quality reproduction / conversion part."
Hmm, maybe they've done something with the circuit board so you don't have to change the wiring harness??
The ones I've done came with a circuit board, but also came with what I call a piggy back harness conversion that is made to integrate into your existing harness, and you have to swap around a few pin outs. In other words, even though I replaced the circuit boards, they still required a partial wire harness and changing some pin outs, which has me curious about your kit. I haven't done a 1st gen bird though and each car I've done varied a little bit in what's required. Over all, it's a pretty easy job. Since they are calling it a conversion kit I have to assume it comes with everything needed for a 1st gen bird. I've just never seen one (till now) that you had to actually swap your needles over. |
I know when I did my 79 Camaro/IA it was basic idiot light cluster and you move some pins in the harness plug for gauges.
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
Sadly, most of the OE gauges I would question the quality, and accuracy, of the readings. Not to mention they are not easy to read.
I would say just go aftermarket, since once you buy that gauge setup, senders, etc, you will probably be in the same territory as an aftermarket setup. New Vintage has a direct fit setup for the 1st gen birds, might want to consider: https://newvintageusallc.mybigcommerce.com/69-firebird/ I have a direct fit setup for my 2nd gen, it is flexible, uses quality senders, are quality construction, and have a good selection of options. If you ever upgrade to some other trans or LEDs, it would integrate easily. .
The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
I actually like/prefer the factory gauges, tach and all. 4 cars here with them, 2 daily drivers. I find them to be pretty accurate so long as you run a "good" sending unit. Not the cheap auto chain store stuff. Seems to work okay for me
Aside from appearance, the issue with aftermarket set ups is limited customization. I have a good tach so wouldn’t need the one in dash.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project Last edited by grivera; 07-21-2021 at 06:58 PM. |
Yeah, the only aftermarket gauges I really like are the old vintage coke bottle Stewart Warner, green line especially. Stuff that fits the period. But I'm an old school junky.
Only going from what I'm reading on the eBay listing, but how can you run these rally gauges with senders that are nothing but on/off switches? I would think that if they were including oil and water sending units they would list them.
https://forums.maxperformanceinc.com...d.php?t=696769 https://forums.maxperformanceinc.com...d.php?t=696769 Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
If it helps Will, I like to use the senders from M&H Electric if they have them for the particular car I'm working on. They seem to be fairly accurate.
Some of the restoration suppliers actually use M&H Electric stuff, they just repackage it, or sometimes they don't and it shows up in an M&H wrapper. But just to be safe and know for sure I'm getting M&H I just order from them direct when I need this kind of stuff. American Auto Wire is another place to check. |
Great tip - thanks!
I plan to check out the conversion kit at Norwalk - Ames said they will have at least one on site.
Anyone here with a factory rally gauge cluster have the part number for the water temperature sender? - or compatible
Also, is it 1/2" NPT?
I found this one from In-line Tube at $35 (INL13700) - with spade connector that I need. Anyone know of a locally available comparable part number?
https://www.inlinetube.com/collectio...rd=%20INL13700
I also have the connectors and terminals, if you go that route, and need it, I can give it to you. .
Thanks Mike - do you have the part number for the Delco Gold?
I looked it up on Rock Auto, part # G1852 :
https://www.rockauto.com/en/catalog/...+/+sensor,4748 I've heard the Standard ones are fine too. ( TS6 ) .
