Can't say I've seen this one, yet: https://www.jegs.com/i/JEGS/555/5108...kaAgcwEALw_wcB
Says it's a new product, that impeller looks pretty nice, and I like how they cast a twisted look the housing casting to differentiate it. I just put a brand new Flowkooler 11-bolt on my car, so who wants to give this new thing a shot??
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop ![]() |
The Following User Says Thank You to nUcLeArEnVoY For This Useful Post: | ||
I don’t get the whole twisted look idea doesn’t seem to add anything Don’t know it has any cooling benefit over the milodon or others
I am happy to see the aftermarket supporting Pontiac’s though. So many other oarts we need more though than duplicates. Like a proper 69 bird license plate bracket.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
![]() Quote:
I recently installed this new Jegs pump.
Aluminum body, composite, (plastic), impeller. Came with two gaskets and a new plate. Has two sets of pulley attach holes, one for Pontiac and the other for Chevy (I guess). No issues installing it. I did the usual plate clearance mod, cools fine
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
The Following User Says Thank You to Singleton For This Useful Post: | ||
![]() Quote:
And a composite impeller, huh? That's interesting. That's one way to prevent corrosion, and most OEM impellers on modern cars are actually plastic/composite... that's definitely a first for Pontiac water pump options, though.
Not all parts are created equal, but after all the years of problems that BMW experienced with using composite impellers in water pumps, I personally would steer clear of any water pump that doesn't use a metal impeller. The composite impellers can crack and sheer off from the shaft, leaving you without coolant flow and an engine that's going to overheat. It was a major debacle for BMW, which is the other automotive universe I'm involved with. This is of course a different design, but composites become brittle with age and heat. Given this is an $84 product presumably manufactured in China, one has to wonder how it will hold up. Time will tell.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 11-22-2021 at 05:57 PM. |
Didn’t measure it, but it was probably .080-.100 clearance initially
