Old 07-23-2023, 05:19 AM
dataway's Avatar
dataway dataway is offline
Default On the Road Shakedown Begins
The GTO went out for the first drive in 40+ years on Sat.
Basically just about 3 miles of driving on the roads around my house.
I found it to be suspiciously problem free.
My home rebuilt TH400 shifted and operated normally ... although I feel the 1st 2nd shift is a few hundred rpm early. (Using original to car modulator)
No surprises with the engine temps (190 +/- 2 degrees), oil pressure at idle 23-25 fully warmed up, 55-60 psi at 2000 rpm (VR-1 20-50), saw it run up to 69 psi blipping the throttle. No detectable leaks yet, cooling system pressurized nicely. No pinging, very quiet valve train (91 octane ethanol free).
Power drum brakes work considerably better than I expected. Firm pedal, very good progressive feel.
I'd say the only thing annoying me is it's got a bit of a rough, "running on 7 cylinders" feel at low rpm acceleration. And a bit of a whine off throttle at cruising speed, not sure if it's the rear end (untouched 100k mile, 2.93) or the trans.
Starts and idles fine, idle drops normally after warm up, but I have a feeling the choke is not opening all the way (driver side of cross over is blocked). Only once did I think I got the back barrels to open .... or it could have just been the trans kicking down. Still taking it kind of easy until I'm confident it's reasonable sorted.
DIY front end alignment seems suitable for this testing, not doing anything unusual except a tiny bit of wandering, tire temps felt fine.
The Following 10 Users Say Thank You to dataway For This Useful Post:
Old 07-23-2023, 06:33 AM
dataway's Avatar
Just spent some time under the car, not a single drop on the floor .. did have one "hanger" drop on the base of the tail shaft .. looks like it might be coming from the Speedo cable hookup.
Checked the diff fluid just in case I happened to forget to fill it .. all good.
Gave the front brakes about five clicks of adjustment on each side, shoes just skimming the drums now.
I see nothing amiss in the ignition, plug wires all in place nicely. I'll check the timing today. I'm running 9 initial, stock iron heads, typical speed-pro pistons with added 6cc dish, about .005 in the hole, typical .037" head gasket (heads cc'd right at 72cc), 068 melling cam, OEM dist internals, and I think an OEM vacuum can.
After many years of only driving late model vehicles it's hard remember what these older cars SHOULD feel like.
The Following 5 Users Say Thank You to dataway For This Useful Post:
Old 07-23-2023, 08:39 AM
Half-Inch Stud's Avatar
Half-Inch Stud Half-Inch Stud is online now
Definitely "check the Timing", yet properly; Time for 34* Total ADV at ~2600 rmp, vac adv hose disconnected, and see what the initial Adv ends up to be. Keep initial under 18* (455).
After that, consider setting up an HEI for best results.
Old 07-23-2023, 08:46 AM
tempest1964's Avatar
That is awesome. Congratulations! Enjoy it now.
The Following User Says Thank You to tempest1964 For This Useful Post:
Old 07-23-2023, 09:36 AM
Shiny Shiny is offline
How fun this must be for you..
Congratulations
Old 07-23-2023, 11:40 AM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
Congratulations! Enjoy it now. find the little things along the way!
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
The Following User Says Thank You to Jim Moshier For This Useful Post:
Old 07-24-2023, 03:50 AM
dataway's Avatar
Here is a boring video of the first drive.
You can hear the whine in the drivetrain. At about 6:30 I stop in front of the house ... drive to the corner and turn around, I come to a stop and move off ... you can hear how quickly the trans is shifting.
The rear end is original to the car, I replaced the axle bearings and seals, replaced the oil. There was a lot of banging and yanking to get the axles out, but I did nothing with the diff (one legged) ... could have harmed something I guess. The rear end sat for about 40 years unused, sometimes inside, sometimes outside, so I'm sure there was some condensation inside. When I had it apart I didn't see anything that looked bad, nothing broken, no metal parts in the oil.
I did noticed that the trans fluid is at least a quart low, can that effect shifting? But I don't think it's trans pump whine, but could be far as I know, I'm not a auto trans guy by any means.
Jeez, after driving modern vehicles with overdrive transmissions this 2.93 feels like a 4.11.
https://www.youtube.com/watch?v=sjt4EtVkiNY
Old 07-24-2023, 10:04 AM
Excellent
Had to be rewarding!
Old 07-24-2023, 04:28 PM
Verdoro 68's Avatar
I bet it feels good and probably a little surreal to get it back out on the road. I also know that the first few drives come with a lot of nerves, but don’t let that get in the way of enjoying this milestone!
Funny that the 2.93s feel steep. I was cruising in the Trans Am the other day and noticed it was 1/2 the RPMs of my ‘68 at 70mph. Those extra three speeds really make a difference!
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 07-25-2023, 01:16 AM
dataway's Avatar
I should have said it feels like a 4.11 in third gear compared to my truck with it's six speed with an overdrive final ratio. From a start the GTO feels pretty normal. I found the hesitancy for it open the rear barrels was more my like of pedal pressure, again use to the fly by wire of most modern vehicles.
Tomorrow I check the timing and point dwell. I suspect it's somehow considerably less than the 9 degrees I originally set it at ... I can really lug it and not a hint of ping. I don't recall that I ever set the timing with the engine in the car ... so I could have moved things around during installation.
If the whine doesn't go away with the addition of more trans fluid then I might end up opening up the rear end.
That another thing ... these old vehicles aren't exactly quiet compared to new ones. More road noise, more wind noise, engine noise etc.
Old 07-25-2023, 02:06 AM
jhein's Avatar
jhein jhein is offline
Looks like a really fun project. Great video..
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 07-25-2023, 12:12 PM
dataway's Avatar
I've had a couple more outings. The initial timing was at 6 degrees, bumped it up to 10 and felt a nice improvement, much crisper on the throttle. Bumped it up to 12 after that, I'll let it sit there for a while. Vacuum advance is kicking in 20 degrees. Starts nicely, idles nicely both in gear and neutral. Starts well when up to temp also. Engine still seems just a tad tight, stops rotating very quickly when shut down. Pressures and temps still where they should be, no dripping so far.
Still whining ... but if I had to make a bet, I'd say it's a bit less ... could just be getting used to it.
And I'm remembering why when I was a kid I removed the hood hinges and used pins on four corners.
Old 07-26-2023, 03:01 AM
NeighborsComplaint's Avatar
Car sounds great. Congrats on getting another legendary car back on the road!
Triple Black 1971 GTO
The Following User Says Thank You to NeighborsComplaint For This Useful Post:
Old 07-26-2023, 04:06 AM
dataway's Avatar
Another Shake Down update ...
So among a few things annoying me I felt the car was a bit more wallowy than I remember, even accounting for the yet to be aligned front end.
So doing my usual late night examination I figured I'd check the body mount bushings. How about this ... with the exception of one on each side just to the rear of the front wheels .... they were all just finger tight, I don't mean hand tight, I mean finger tight, I could unscrew them all with my fingers.
Evidently when I finished adjusting the body position and all the front body panels I for some reason only tightened the ones behind the front wheels.
Test drive will have to wait till tomorrow ... wondering if I will notice a difference.
Bit by bit I'll get it right
Old 07-26-2023, 10:17 AM
Greg Reid Greg Reid is online now
That 068 sounds good. Congratulations on reaching this milestone!
Old 07-27-2023, 05:05 AM
dataway's Avatar
If anyone ever wondered .... having 80% of the body mount bushings bolts so loose they could almost fall out makes little difference in daily driving
Car runs better with the initial timing bumped up to 12. Topping up the trans fluid made no detectable difference. I manually shifted the car and it shifts wonderfully, firm but not harsh.
Are OEM modulators adjustable at all? Still seems to be shifting too early by at least 300 rpm.
Old 07-27-2023, 09:02 AM
I've never done it but I believe they are adjustable. What are the shift points supposed to be? Mine is set up just as it was when I got it and I have no idea whether it's right.
My initial timing is set to 14* if I recall correctly.
Old 07-27-2023, 09:28 AM
PunchT37's Avatar
PunchT37 PunchT37 is online now
Cool deal. 40 years, huh? Run that thing. You`ll figure that thing out.
Late model cars? Yeah but, how many eyes does that car get?
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 07-27-2023, 11:05 AM
OG68 OG68 is offline
I think the shift points are in the service manual (TH400 Chapter) and IIRC they were quite low under minimal throttle.
2007 Cadillac SRX
The Following 2 Users Say Thank You to OG68 For This Useful Post:
Old 07-27-2023, 11:58 AM
I know mine shifts 1-2 very quickly on normal takeoff from a stop but since the change to the 3.55 rear, if I goose it immediately after the shift it'll chirp the tires in the downshift back to 1.
