Old 08-30-2023, 02:42 PM
SD421's Avatar
SD421 SD421 is offline
Default Reproduction Dash Bezel Issue
Hi,
Wanted some advice on this Instrument Housing Bezel.
Long story short, received my first one a couple of weeks ago and then sent it back.
Trash in the “chrome” as well as noticeable discoloration in the corners.
Just received the 2nd bezel and while it’s better there is still discoloration in the corners.
For $380, would you send it back again for another one??
FYI, The Parts Place and Ames sell the same one.
In the pics, I’ve circled it in yellow.
Thanks,
Don
ID:	619101   Click image for larger version
ID:	619102   Click image for larger version
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 08-30-2023, 06:18 PM
RedDirtRoad RedDirtRoad is offline
Where did you buy the bezel from?
Old 08-30-2023, 07:11 PM
SD421's Avatar
The Parts Place but in talking to Ames today about another issue I asked them where they got there’s from and it’s The Parts Place
1966 GTO
1966 Tri-Power
1967 670 Heads
Old 08-31-2023, 12:42 PM
geeteeohguy's Avatar
The ones I have seen in the past were perfect. A buddy got one for his '65 about 15 years ago (still un-installed) and it is jewel-like quality. I wonder if the manufacturing process has changed? Hopefully others will chime in. For close to $400, I would not be a happy camper.
Jeff
The Following User Says Thank You to geeteeohguy For This Useful Post:
Old 08-31-2023, 07:50 PM
ZeGermanHam's Avatar
The dash bezel that I bought from Ames in 2021 for my '66 is pretty perfect in those locations. It was also a Parts Place unit purchased through Ames.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 08-31-2023, 08:45 PM
What's with the blue colour on the face of a '66 bezel?
Old 08-31-2023, 09:56 PM
GtoFM's Avatar
GtoFM GtoFM is offline
I spoke with a vendor at the 2022 Good Guys Meet in Columbus, OH. He uses a vacuum process to restore the chrome on your parts. I haven't seen any of his work other than samples, which of course, looked better than new.
Steve Grybel
whitewallsteve@vacuumorna-metal.com
Vacuum Orna-Metal
11380 Harrison St.
Romulus, MI 48174
734-941-9100
The Following 2 Users Say Thank You to GtoFM For This Useful Post:
Old 09-01-2023, 09:42 AM
SD421's Avatar
Supposed to be the stock color for a Tempest/LeMans
1966 GTO
1966 Tri-Power
1967 670 Heads
Old 09-01-2023, 03:14 PM
I hate to be the bearer of bad news but after I read your post about sub par chrome on the bezel I checked the bezel I bought last month that’s been in an unopened box since I received it.
The bezel I bought from Parts Place is perfect
Maybe it’s just a bad batch of a few
The Following User Says Thank You to RedDirtRoad For This Useful Post:
Old 09-01-2023, 06:08 PM
SD421's Avatar
No worries. They said that they do check before shipping.
They are supposed to go out into their inventory and do a search for a nice one before sending out.
I’m glad yours is nice which lets me know they are capable of having nicer bezels.
1966 GTO
1966 Tri-Power
1967 670 Heads
The Following User Says Thank You to SD421 For This Useful Post:
Old 09-01-2023, 06:10 PM
SD421's Avatar
Steve Grybel
Vacuum Orna-Metal
11380 Harrison St.
Romulus, MI 48174
734-941-9100
Funny you should mention them.
I got a quote for $398 just to strip it and vacuum metalize it.
I’d still have to paint it (if this 3rd bezel they send me is also bad I just might go that route)
1966 GTO
1966 Tri-Power
1967 670 Heads
Old 09-02-2023, 11:38 AM
Cammer-6 Cammer-6 is offline
what ever you do dont use the jacazzes in Tallahassee.
I sent them a very hard to find 68 Firebird round remote mirror
that they ruined and sent back with a refund and some of the worst
attitude Ive ever experienced.Hemmings wouldnt back me(where they advertised)
so they also lost me as a customer.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 09-02-2023, 11:56 AM
I think I know the company you’re talking about. Do they advertise parts on eBay with ridiculously high prices?
Old 09-02-2023, 12:29 PM
Not really. You had a LeMans. The cluster tunnels are blue/green, but the pebble grain on the dash is black. At least IIRC. The '64 and '65 have black plastic and black tunnels. The '66 and up have those classy blue/green tunnels. About the same color as the '64's have between the console ribs and dash trim ribs. Weird.
Glad to hear that they ARE capable of producing nice units still. Sounds like they need a more scrupulous Q.C. inspector.
Jeff
Old 09-02-2023, 04:21 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Hi Jeff,
Slight correction about the gauge tunnel color.
Only 1967 had the blue/green colored tunnels.
This color was used on the ‘67 radio face as well.
1966 still had black tunnels.
My OEM ‘66 dash below.
PS, the chrome outer lip of the tunnel openings on a ‘67 is slightly rounded.
1966 chrome lip is flat.
ID:	619276   Click image for larger version
The Following 3 Users Say Thank You to 60sstuff For This Useful Post:
Old 09-02-2023, 05:38 PM
Originally Posted by 60sstuff View Post
Hi Jeff,
Thanks, Chris. Haven't owned a '66 in 33 years. Feel free to post more pics of that beautiful interior....it never gets old!!! And everybody, have a great long weekend.
Jeff
Old 09-03-2023, 10:24 AM
Kenth's Avatar
Kenth Kenth is offline
Hi Jeff,
I noticed your steering wheel center cap has silver rings around the arrow head, mine doesn´t.
Has someone changed mine or was there two styles, early/late?
Thanks!
Name:	Steering wheel center cap.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-03-2023, 12:12 PM
60sstuff's Avatar
Thanks!
I can’t explain why there are two different styles of the ‘66 steering wheel center cap.
From reviewing the ‘66 Lemans and GTO Survivors I have on file my guess is about 25% are like yours, without the 3 chrome rings.
Also it does not seem to be early verses late production or plant build, or Lemans / GTO as I have seen both caps on each model.
Maybe a supplier for a period of time caused this?
Here is a close up of my center cap, plus a spare cap with part number on the back #9783136.
ID:	619306   Click image for larger version
ID:	619307   Click image for larger version
Old 09-11-2023, 07:20 PM
The horn cap on my '66 is a little different than either of those two styles. The rings are not the same blue as the background nor are they bright silver like the arrowhead. Instead, the rings are somewhat of an iridescent blue that catches the light, but definitely not silver.
