My Moser 12 Bolt Swap, Auto, Driveshaft and Part # Info Inside
Here are some things I'll pass on...
1969 GTO, had 8.2 rear end Moser 12 Bolt, 3:70 gear, 11" Wilwood brakes, no back brace, powercoated, 33 spline Truetrac, stock axle length = $6000 IF you frame notch or tub etc, you must be very clear with them you did this if you ask for a 1 to 2" housing shortening/chop. They have a great online form but this area of the form sucks, no details on drop-down, they called my shop and changed my GN 9" order because they assumed I ordered it wrong, they cost me $800 in powdercoating on their error, they won't take blame and you'll have to make a hard choice, eat it or bail. Truetrac needs Sae 80w-90 heavy duty gear oil Part #: 10043 TH400 trans needed a 57.5" long driveshaft, factory won't fit. PST 3.5" Aluminum was $575, was 1 full week from order to make, ship, receive. 3" steel vs 3.5" Aluminum is 22lbs vs 15lbs, 7lb drop here is nice. You'll need the UMI 5" ID, DS safety loop for 3.5" + DS https://www.umiperformance.com/home/...t-safety-loop/ Rear Shocks need the 1" bearing due to narrow mount Moser bracket offers, Viking has them, $25. I'll drive it again soon after a disastrous 2023 engine mess, this should be plenty to handle my power level and way more.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump |
The Following User Says Thank You to GOAT8U2 For This Useful Post: | ||
Can you elaborate about the shock bearings? I'm noticing my Bilstein shocks ride pretty close to the rear end housing with the Moser rear.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
Here is a link
https://midwestchassis.com/products/...s-to-1-bearing These are more narrow to fit into the brackets better, I run Viking so that is the part number above. $25 through Viking.
Are those for the coilover brackets or traditional shocks? I was thinking I needed something to move the shock away from the axle a little bit.
Viking Berzerker, Double Adjustable Coilovers.
I tried the BMR bracket but it won't work. I'm getting a custom bracket made for this later, inside mounting too.
I have regular shocks bolted directly to the rear end so I think what I have going on is a different. They aren't rubbing, just a little too close for comfort. For now I added a washer between the shock mount and the rear end.
