Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 2
1
2
Showing results 1 to 25 of 36
Search took
0.01
seconds.
Search:
Posts Made By:
Green Hornet
Forum:
70-73 Firebird & TA TECH
06-25-2023, 03:05 PM
439
1970 One year only parts
65,660
Posted By
Green Hornet
I thought early trunk release buttons were green..
Forum:
61-66 Big Pontiac TECH
04-30-2023, 04:01 PM
14
wagon question?
886
Posted By
Green Hornet
They are pretty obscure.....Only available on...
They are pretty obscure.....Only available on Catalina with 3rd row seat option...
Not available on Bonneville......IIRC....
They bolt to bumper face.....with the fingers supporting them...
Forum:
77-81 Firebird & Trans Am TECH
09-22-2022, 04:03 PM
8
79 TA Brake Booster
1,265
Posted By
Green Hornet
With all due respect to Inline Tube....alot of...
With all due respect to Inline Tube....alot of their application data is wrong...
I ordered a "correct" 70-74 reverse shift rod...for my 72 TA.....and the one they sent is for a A body...Not even...
Forum:
08-29-2022, 11:55 PM
4
Nice JW on ebay..
1,208
Posted By
Green Hornet
Realistically.....It's a planter...:rolleyes:
Forum:
07-05-2022, 03:56 PM
49
Production numbers on W72 Y88's
7,622
Posted By
Green Hornet
Depending on the date your car was...
Depending on the date your car was ordered.......WS6 and W72 were sold as a combined option..or individually spec'd....
W72....by itself was like $50.......IIRC
Forum:
05-12-2022, 01:14 AM
15
correct front sway bar brackets and bushings
1,857
Posted By
Green Hornet
Pictured brackets came of a 1 1/4" front...
Pictured brackets came of a 1 1/4" front bar........which was standard on Trans am....and available (but uncommon ) on a Formula.
Those brackets use a socket head cap screw.....with a small...
Forum:
05-04-2022, 01:20 AM
11
disc vs. drum axle shafts
1,564
Posted By
Green Hornet
I believe they will interchange...but carried a...
I believe they will interchange...but carried a different P/N....due to the rear disc part using a slightly longer axle stud to accommodate the extra thickness of rotor..
Forum:
04-01-2022, 08:03 AM
30
1970 Power Steering Pumps
2,771
Posted By
Green Hornet
That being said.....a 70 bird...with a 350...
That being said.....a 70 bird...with a 350 2bbl.....has become rarer...than a 70 TA..:cool:
Forum:
03-30-2022, 05:41 PM
30
2,771
Posted By
Green Hornet
I believe the crank pulley is the same for...
I believe the crank pulley is the same for 68-70 A and B body...
Forum:
03-28-2022, 01:22 PM
30
2,771
Posted By
Green Hornet
FYI water pump pulley is is year only Firebird...
FYI water pump pulley is is year only Firebird specific....IIRC..Both AC and non...
Forum:
02-14-2022, 11:32 PM
97
Original motor options
9,107
Posted By
Green Hornet
Under the blower housing....on firewall..on...
Under the blower housing....on firewall..on non-AC.....
AC cars have a 2nd one under evap housing...
Forum:
02-10-2022, 10:43 PM
97
9,107
Posted By
Green Hornet
Just to muddy the water a bit....I guess that...
Just to muddy the water a bit....I guess that VIN: 20N110363 could also be from a formula 400?
Forum:
02-08-2022, 01:42 AM
15
M22 Questions/Value?
2,160
Posted By
Green Hornet
No interest is a 5 speed at all for this car.... ...
I would just get a new mustang if I wanted more gears....:cool:
I have old cars... to experience them...as they were built........
Forum:
02-07-2022, 03:25 PM
15
2,160
Posted By
Green Hornet
You just need a car......with a bigger motor...:D...
I run one in my 71 TA with 3:42's.....and it has no problems in first gear...other than traction....
Forum:
02-07-2022, 09:26 AM
15
2,160
Posted By
Green Hornet
Doing a 4-speed conversion on a 72 TA.
It's pretty original and #'s matching under the hood..
I have a perfectly good Super T-10 that I was going to use......but found an M22 locally that am...
Forum:
02-05-2022, 04:17 PM
97
9,107
Posted By
Green Hornet
Too late.....It appears...that you have already..
Forum:
02-05-2022, 02:58 PM
97
9,107
Posted By
Green Hornet
Couldn't hurt to post the vin stamp... There...
There could be someone out there that needs it....
Forum:
01-30-2022, 04:41 PM
6
Who makes the correct blue interior dye for 1970 Trans Am?
1,933
Posted By
Green Hornet
There is no such thing as vinyl die....It is...
There is no such thing as vinyl die....It is actually paint...
Vinyl is not porous...and will NOT absorb anything...
Have yet to find a close match.....
Best to take a nice original sample...
Forum:
01-27-2022, 11:21 AM
13
72 Formula spied on Craigslist.
1,457
Posted By
Green Hornet
Nice looking car..........but the wheels....and...
Nice looking car..........but the wheels....and thingy on the trunk leave me cold.....Looks camero-ish..
Price could be optimistic....for a "small block"...:D
Forum:
01-24-2022, 10:29 PM
35
'nother W66 HO
5,903
Posted By
Green Hornet
It seems that most 71-72 W66's....with LS5's are...
It seems that most 71-72 W66's....with LS5's are heavily optioned...
Forum:
01-14-2022, 10:25 PM
17
Driveshaft differences 77 fbody MT vs AT
3,034
Posted By
Green Hornet
In 77...M21 was an ST-10.....The Muncie 4 speeds...
In 77...M21 was an ST-10.....The Muncie 4 speeds went away in mid 74....and option code for all ST-10s remained as M21..till 79 anyways
M20...was likely a Saginaw in those years....which used the...
Forum:
74-76 Firebird & TA TECH
12-26-2021, 07:56 PM
5
Electric trunk in 74?
1,660
Posted By
Green Hornet
I bought a heavily optioned 71 TA from original...
I bought a heavily optioned 71 TA from original owner about 35 years ago......and it had one (factory installed)
Push button in glove box was green IIRC......not yellow like the later 70's..
Forum:
10-24-2021, 11:30 PM
48
My new 1970 Trans Am
8,542
Posted By
Green Hornet
I believe the 3:73 performance rear axle was not...
I believe the 3:73 performance rear axle was not specific to M21 in that year.
My friends 70 TA auto has that option on the invoice...IIRC
Forum:
Pontiac - Street
10-06-2021, 02:27 PM
89
068 cam.....in a 350
11,302
Posted By
Green Hornet
Thanks...for everbodys input..... Subject 74...
Subject 74 350...is just a mule engine...to get my 73 up and running....
I think the plan is to drive it first...with the 2 bbl...and then decide if I want to...
Forum:
09-08-2021, 02:29 PM
11
Non-TA buildsheet for Olds 350/403
3,049
Posted By
Green Hornet
With all due respect to your car...engine...and...
With all due respect to your car...engine...and your interest in it....
77 Firebirds with 350 olds engines....were a California ONLY deal....if I am not mistaken.....which means that very few were...
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
10:42 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
