Showing results 1 to 9 of 9
Search took 0.01 seconds.
Search: Posts Made By: 68tpls400
Forum: 74-76 Firebird & TA TECH 10-01-2023, 07:53 PM
Posted By 68tpls400
Yes, I have them on both of my '76 t/a's.
Forum: 67-69 Firebird TECH 03-30-2023, 12:21 PM
Posted By 68tpls400
Certainly "not a problem", but if it did pop...
Certainly "not a problem", but if it did pop open, there is no secondary safety like '68-'69.
I've driven '67's for the past 30 years and have never had a hood opening problem.
Forum: 77-81 Firebird & Trans Am TECH 02-21-2023, 09:45 PM
Posted By 68tpls400
You should check with John from Second Gen...
You should check with John from Second Gen Graveyard for all of the items you listed. I think he's on vacation until next week, but if you email or fb message him, he can help you out.
Forum: 74-76 Firebird & TA TECH 01-24-2023, 09:03 PM
Posted By 68tpls400
Second Gen Graveyard will get you the best...
Second Gen Graveyard will get you the best pricing on those items.
I have a bunch of seats I parted out if you need some used seat springs. Have a couple of tracks and other seat parts too if anyone...
Forum: 67-69 Firebird TECH 06-04-2021, 10:58 AM
Posted By 68tpls400
Those brackets mount under the front shakers for...
Those brackets mount under the front shakers for '68. If you actually have '67 shakers, I don't think you need them. All three years' front shakers are different. (many people sell them as '67-'69,...
Forum: 67-69 Firebird TECH 05-05-2021, 09:01 AM
Posted By 68tpls400
Not a factory option. I believe some dealers may...
Not a factory option. I believe some dealers may have added aftermarket.
Forum: 77-81 Firebird & Trans Am TECH 01-26-2021, 10:39 AM
Posted By 68tpls400
Trim tag indicates 19U 19L. Black, not red. ...
Black, not red.
Does not match PHS?
Trim tag also shows it is a SAD car. :(
Forum: 67-69 Firebird TECH 12-04-2020, 01:17 PM
Posted By 68tpls400
The way the louvers are shaped, this would not...
The way the louvers are shaped, this would not work well and look goofy.
You would be better off grafting in the louver section from a '67-'68.
Forum: 67-69 Firebird TECH 08-20-2020, 02:34 PM
Posted By 68tpls400
I recommend keeping the top up and latched as...
I recommend keeping the top up and latched as much as possible. Even leaving it down a week will lead to some bad words trying to stretch it back into place enough to properly latch it.
Usually 2-3...
