Showing results 1 to 25 of 26
Search took 0.01 seconds.
Search: Posts Made By: djustice
Forum: Exhaust TECH 10-07-2025, 02:39 PM
Posted By djustice
Well here i am back again in this thread, i...
Well here i am back again in this thread, i finally orderd these headers, they are now at customs clerance into norway, just forked out 360 bucks in tax, and they should be here shorty.
The car is...
Forum: Pontiac - Street 09-27-2024, 09:13 AM
Posted By djustice
New line of camshafts at butler, max HP series.
Looks fairly agressive, i'll be bench racing these in my head.
https://butlerperformance.com/c-1459688-camshafts-cam-kits-max-hp-camsboosted-nitrous-naturally-aspiratedhydraulic-rollercams.html
Forum: Interior TECH 08-16-2024, 05:40 PM
Posted By djustice
New Speedhut gauges, designed for firebirds.
They just launched a new design, and it looks real good, almost like the original with a few modern touches.
https://www.speedhut.com/categories/gauge-applications/pontiac.html
This was 1...
Forum: 70-73 Firebird & TA TECH 08-16-2024, 05:20 PM
Posted By djustice
A Few from Hot august nigths in trondheim Norway...
A Few from Hot august nigths in trondheim Norway last week.
https://i.postimg.cc/8fsgRMrS/IMG-0002-2.jpg (https://postimg.cc/8fsgRMrS)
https://i.postimg.cc/rzpT2XZP/IMG-3095.jpg...
Forum: Pontiac - Street 08-06-2024, 07:09 PM
Posted By djustice
You migth be on to something here, I know i said...
You migth be on to something here, I know i said in my original post that i changed wiper arms, that was a brain fart, i ment wiper blades. But i did remove just the drivers side wiper arm and...
Forum: EFI Tech 09-22-2023, 06:02 AM
Posted By djustice
Solved! I belive the jerry rigged PCV and all...
Solved! I belive the jerry rigged PCV and all other PCV/breather setup was wrong for the engine.
The solution to my problems was Fresh airline from aircleaner housing to valve cover. ME wagner...
Forum: Exhaust TECH 09-05-2023, 08:58 AM
Posted By djustice
My impression is that headers that come finished...
My impression is that headers that come finished with ceramic coating is not as good as a dedicated ceramic coating shop. So that is the way i plan on doing it, buying them with black protective...
Forum: Pontiac - Street 05-19-2023, 09:42 AM
Posted By djustice
Update: I passed the second inspection. wheel...
Update: I passed the second inspection. wheel cylinders replaced, and the 6 contact points where the brakeshoes rest was coated with copper grease, it took 2-3 tests on the rolling road brake tester...
Forum: Pontiac - Street 05-09-2023, 02:27 PM
Posted By djustice
I am back from the testing, and i had currently...
I am back from the testing, and i had currently no vacuum in the crank case. i removed 1 of my 2 breathers, and locked it off, fitted the home made fixed orifice pcv but was still not pulling vacuum....
Forum: 70-73 Firebird & TA TECH 08-16-2022, 11:36 AM
Posted By djustice
https://i.postimg.cc/J0Pd8jyX/IMG-2674.jpg A...
A quick picture of drivers side.
Forum: Pontiac - Street 07-16-2022, 07:41 AM
Posted By djustice
Converter stall speed observations with new heads, intake and cam.
I recently Rebuildt the engine with a topend kit, my limiting factor for cam choiche was converter stallspeed before the topend rebuild, and not knowing what cam was inside the engine.
After...
Forum: EFI Tech 07-06-2022, 03:17 PM
Posted By djustice
Update! I posted in the facebook efi owner's...
Update!
I posted in the facebook efi owner's group, no answer for 3 days til today where one person had the same issue as me, he said his 02 sensor wiring had chafed off and was rubbing against...
Forum: EFI Tech 07-06-2022, 03:56 AM
Posted By djustice
Wow! that is bad, need to check that my bluetooth...
Wow! that is bad, need to check that my bluetooth keyboard is putting out all words i type in the future.
Forum: EFI Tech 07-05-2022, 01:20 PM
Posted By djustice
The sop that sol it to me got back to me just...
The sop that sol it to me got back to me just now. He had contacted holley and relayed my story. the only thing that they could tink off that i had not done yet was to pull the fuelpump relay and see...
Forum: Pontiac - Street 06-21-2022, 08:17 AM
Posted By djustice
Top end rebuild
Refresh of motor, with butler topendkit.
base shortblock estimated buildt around 2005-ish:
73 casting 455 bored 60 over = 469 piston is 0.001 in the hole
Speedpro L2359 .060 pistons
stock "N"...
Forum: 70-73 Firebird & TA TECH 06-17-2022, 04:28 PM
Posted By djustice
Thank you, i have a tube of 3m weatherstrip...
Thank you, i have a tube of 3m weatherstrip adhesive i'll give it a shot
Forum: Pontiac - Street 12-10-2021, 05:06 AM
Posted By djustice
Main power and ground (heavy red and black wires)...
Main power and ground (heavy red and black wires) straigth to battery. The battery is like a buffertank it smooths out incomming and outgoing power spikes, unlike distribution lugs og starter lug...
Forum: 70-73 Firebird & TA TECH 12-07-2021, 03:42 AM
Posted By djustice
I want stealth appearing heads because the car is...
I want stealth appearing heads because the car is registerd as a historic vihecle. And in for it to pass the DMV mandatory checks, it has to be stock or stock apering. But some DMV inspection...
Forum: 70-73 Firebird & TA TECH 08-16-2021, 04:18 AM
Posted By djustice
Trying out one of these new Ceramic Coating that...
Trying out one of these new Ceramic Coating that have been hyped: Gyeon MoHs
After a 2 step pholish, first step: rupes yellow woolpad + Scholl S20 black -> over to Rupes yellow polish
Second Step,...
Forum: Pontiac - Street 08-03-2021, 09:10 AM
Posted By djustice
I can confirm the 4-hole spacer whistle-fix. I...
I can confirm the 4-hole spacer whistle-fix. I have an edelbrock performer , and with an open edelbrock heat insulator gasket 1/4" thick there was a loud whistle under part throttle, i bougth a...
Forum: The Body Shop TECH 07-01-2021, 07:42 AM
Posted By djustice
A cropped image from hot august nigth in...
A cropped image from hot august nigth in Trondheim Norway 2019 , taken by proffesional photgraper, but a lot have been alterd on the car since then.
I live about 30 minutes away from the iconic...
Forum: The Body Shop TECH 07-01-2021, 06:42 AM
Posted By djustice
In the Shop for rust repair
Currently the car is in the bodyshop, been there for just under 3 weeks, and i guess it will be done in the very soon. i uploded som pictures before it went in.
Pretty exited to see the blend-in job...
Forum: THE LOBBY 02-01-2021, 11:23 AM
Posted By djustice
There is a dedicated database/search engine just...
There is a dedicated database/search engine just for cars in movies:
https://www.imcdb.org/
I have wasted many hours on this one :D
Forum: 70-73 Firebird & TA TECH 10-15-2020, 07:04 AM
Posted By djustice
I just changed springs and shocks on my 73'...
I just changed springs and shocks on my 73' formula, the old ones where eibach (i think) and som unknown brand shocks.
Previous owner have some how FUBAR'ed the springs, by not lining them up in the...
Forum: THE LOBBY 09-15-2020, 09:25 AM
Posted By djustice
Yes, 370 net (hopefully) HP from an low...
Yes, 370 net (hopefully) HP from an low compression iron head engine with lots of blowby is impressive. It will be interesting to see what they do to cure the blowby, probably new rings.
