Showing results 1 to 8 of 8
Search took 0.05 seconds.
Search: Posts Made By: Snowbound
Forum: Pontiac - Street 01-26-2026, 01:40 AM
Posted By turbo69bird
I don’t see why line boring would necessarily be...
I don’t see why line boring would necessarily be needed. I’d get some caps off a junk rear and install them with bearings and races see how they fit the rear should be inline with the axle bearings...
Forum: Pontiac - Street 01-25-2026, 10:08 PM
Posted By AG
I've used Strange billet aluminum caps on GM 8.5"...
I've used Strange billet aluminum caps on GM 8.5" and 12-bolt rears and they work great. Just need assembly, ID measurement and possible machining.
Forum: Pontiac - Street 11-20-2025, 04:05 PM
Posted By Skip Fix
#15 heads from a 1970 455 are not too bad for a...
#15 heads from a 1970 455 are not too bad for a little more compression either. Supposed to be 87 cc. Just have press in studs though.
Forum: Pontiac - Street 11-19-2025, 09:23 PM
Posted By b-man
6X-8 heads maybe 8:1, 6X-4 will be 8.5:1 at best....
Choose your cam accordingly.
I’d be looking for 1970 #13 400 heads, usually around 77 to 80cc chambers although advertised as 72cc. This will...
Forum: 64-65 GTO Tempest & LeMans TECH 10-19-2025, 10:48 AM
Posted By Joe
I just obtained a repop hood for cheap. OEM scoop...
I just obtained a repop hood for cheap. OEM scoop does not fit. Also, the under bracing has 2 square cutouts that the OEM hood did not have. Slight depression in the scoop area as other have stated....
Forum: 64-65 GTO Tempest & LeMans TECH 10-17-2025, 01:07 AM
Posted By Baron Von Zeppelin
If you find an actual 65 hood in mint cherry...
If you find an actual 65 hood in mint cherry condition , it is probably worth the extra price.
65 didn't have the front hood emblem crest.
66 hood is a good alternate too.
Forum: 64-65 GTO Tempest & LeMans TECH 10-15-2025, 11:28 PM
Posted By carcrazy
Overall pretty good....a little lighter than an...
Overall pretty good....a little lighter than an original. There is also a low spot adjacent to the scoop that needs some work. As noted previously, the original scoop insert doesn't fit...
Forum: 64-65 GTO Tempest & LeMans TECH 10-15-2025, 07:18 PM
Posted By Cardo
They're pretty good but not perfect. They have to...
They're pretty good but not perfect. They have to use the 67 style bolts instead of the 65-66 studs with nuts. Metal wise, they're usually slightly cupped around the sides of the scoop. That can be...
