Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 20
1
2
3
11
Last
Showing results 1 to 24 of 500
Search took
0.06
seconds.
Search:
Posts Made By:
grivera
Forum:
66-67 GTO Tempest & LeMans TECH
06-04-2024, 06:10 PM
28
Is the Steering Column Ruined
562
Posted By
ZeGermanHam
The whole column assembly has to come out of the...
The whole column assembly has to come out of the car, but it sounds more difficult than it actually is.
It's pretty simple in the end. There aren't that many parts inside the column, and nothing...
Forum:
06-04-2024, 05:55 PM
28
562
Posted By
'ol Pinion head
Easy rebuild on the early straight column. Be...
Be very careful when removing the lower bearing assembly from the end of the tube.
Forum:
Pontiac - Street
06-04-2024, 06:44 AM
30
Motor oil weight you run?
969
Posted By
59safaricat
15/40 non synthetic diesel oil of your choice...
15/40 non synthetic diesel oil of your choice (whatever is cheap). There's a good amount of detergent in them to slowly clean things up internally but no so much (like an engine flush) that it causes...
Forum:
Pontiac - Street
06-02-2024, 07:52 PM
30
969
Posted By
Tim Corcoran
It depends on your bearing clearances. If factory...
It depends on your bearing clearances. If factory clearances 10-30 is recommended with a little more clearance 10-40 or 15-40
Forum:
06-02-2024, 09:01 AM
28
562
Posted By
'ol Pinion head
'67 GM A-B-F-body columns all had the Energy...
'67 GM A-B-F-body columns all had the Energy Absorbing feature. This redesign for this model year of both GM car standard, as well as tilt columns included numerous features. The new safety features...
Forum:
Pontiac - Street
05-25-2024, 03:55 PM
46
High Torque Starters
2,314
Posted By
Dragncar
My 2 cents on starters. You need a plain mini...
My 2 cents on starters. You need a plain mini starter. The Summit starter is the one to get. I have had one forever, no issues. 166 $ and made by CVR. Multiple clocking positions.
Forum:
Pontiac - Street
05-23-2024, 04:47 AM
15
Exhaust idle notes
525
Posted By
64speed
https://youtube.com/shorts/tFebY_Tq3YE?si=vU9mSAuH...
https://youtube.com/shorts/tFebY_Tq3YE?si=vU9mSAuHfpbht6N5
Forum:
Pontiac - Street
05-19-2024, 08:12 AM
15
Help Decipher CC HR Cam
842
Posted By
Cliff R
I used SD's Old Faithful cam 236/245/112 in my...
I used SD's Old Faithful cam 236/245/112 in my last 455 at 11.3 to 1 compression. It was pretty "tame" at idle making 13.5" vacuum at 750rpm's with only 10 degrees initial timing. Fine on pump gas...
Forum:
Pontiac - Street
05-16-2024, 05:12 PM
16
Questions Re: Manual 4 Wheel Disc Brakes Conversion
376
Posted By
Formulajones
Corvettes we're built in The 10's of thousands...
Corvettes we're built in The 10's of thousands with 4 wheel manual disc brakes starting in 65 and continued the trend with manual into the mid 70's. Power was an option.
I did 4 wheel manual disc...
Forum:
Pontiac - Street
05-16-2024, 01:25 PM
16
376
Posted By
65madgoat
7/8" master cylinder and go smaller (3/16") on...
7/8" master cylinder and go smaller (3/16") on brake line to the rear is my advice going manual. Manual works great when set up right.
Forum:
Pontiac - Street
05-16-2024, 01:23 PM
16
376
Posted By
Scarebird
This is nonsense. A lot of factory cars...
This is nonsense.
A lot of factory cars had manual disc in the 60's till the mid 70's; Corvettes, Camaros, Firebirds, and especially Mustangs. I have hands-on converted several vehicles to...
Forum:
05-10-2024, 08:36 AM
1
66 Lemans Coil Springs and Ride Height
193
Posted By
android 211
There was a guy who parted out Pontiacs a few...
There was a guy who parted out Pontiacs a few miles from my house. He sold me a set of coil springs that came off a 66 or 67 Lemans that still had the ID tags on them. The fronts said 'Moog HD' and...
Forum:
Interior TECH
05-06-2024, 02:56 PM
8
eBay Seat Foam
529
Posted By
b-man
Bought some foam for my Le Mans convertible...
Bought some foam for my Le Mans convertible buckets from Ames a couple weeks ago. Ordered complete Legendary upholstery in Saddle at the same time, about an 8 month wait for that.
They have a...
Forum:
Pontiac - Street
05-06-2024, 09:20 AM
11
Traded the 64 Lemans for a 66
395
Posted By
johnta1
Congrats! Good looking 66. :)
Congrats!
Good looking 66.
Forum:
Interior TECH
05-06-2024, 01:18 AM
8
eBay Seat Foam
529
Posted By
Entropy11
ACI for a sure thing quality/fit/feel. If I were...
ACI for a sure thing quality/fit/feel. If I were to gamble on any other set of foams it would be these (also USA made) : https://www.thorntonmusclecars.com/product-page/bucket-seat-foam-full-slot
Forum:
Pontiac - Street
05-03-2024, 02:30 PM
19
What’s this 421 worth?
829
Posted By
steve25
I am trying to find my notes from 25 years ago ...
I am trying to find my notes from 25 years ago in regards to the valve to piston clearance deal, but here’s what I recall off of the top of my head.
Using 428 pistons in a 421 build with its...
Forum:
Pontiac - Street
05-03-2024, 01:36 PM
19
829
Posted By
b-man
Not really because the 421 block has a pretty...
Not really because the 421 block has a pretty robust casting compared to the 389s. However that much overbore kind of diminishes the value to a certain extent. When I bought my 421 it was standard...
Forum:
Pontiac - Street
05-03-2024, 12:10 PM
19
829
Posted By
b-man
Absolutely not 421 pistons. The valve reliefs are...
Absolutely not 421 pistons. The valve reliefs are completely different on a 421.
The valve reliefs and dish shown are what forged 428 replacement TRW/Sealed Power 12cc pistons all look like.
Forum:
Pontiac - Street
05-03-2024, 11:53 AM
19
829
Posted By
b-man
Standard bore size is 4.09375” for the 421. ...
4.120” is standard bore for the 428.
4.160” is +.040” for the 428 pistons so you’re poking that 421 .06625” over which seems excessive unless the...
Forum:
Pontiac - Street
05-03-2024, 10:58 AM
19
829
Posted By
John Milner
The pin height will be the same. You would just...
The pin height will be the same. You would just have to be careful about running much lift if you used the 76 heads as the valve angles do not match up with the valve reliefs in the 428 pistons. I...
Forum:
Pontiac - Street
04-29-2024, 08:55 PM
18
421 Block - Sevice Replacement?
920
Posted By
tom s
I think the correct term was "fitted block"no...
I think the correct term was "fitted block"no crank or rods.Tom
Forum:
Pontiac - Street
04-22-2024, 08:04 PM
20
.005 or .010 shorter cam chain needed?
1,205
Posted By
65 Lamnas
I don't think it's a "shorter chain" when you're...
I don't think it's a "shorter chain" when you're buying that type of timing set. At least that's how it is with Rollmaster. With those .005 and .010 sets, the chain is the same as in the standard...
Forum:
Pontiac - Street
04-13-2024, 03:52 PM
98
8.2 upgrade options
5,365
Posted By
Verdoro 68
The 33 spine TrueTrac is $35 more than a 30...
The 33 spine TrueTrac is $35 more than a 30 spline ($510 vs $475).
I put my order in online and a rep from Moser called me about 30 minutes later to run through the config and answer any...
Forum:
Pontiac - Street
04-07-2024, 08:03 PM
24
exhaust manifold paint
1,120
Posted By
Verdoro 68
I've been really happy with the Eastwood manifold...
I've been really happy with the Eastwood manifold coating in spray cans. It lasted longer than the powder coating I had done and is easy to touch up if you need to.
Page 1 of 20
1
2
3
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
03:56 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
