Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Showing results 1 to 17 of 17
Search took
0.01
seconds.
Search:
Posts Made By:
Nobuddy
Forum:
Pontiac - Street
02-26-2024, 01:28 AM
21
Crower Cam Saver or Hylift Johnson?
1,678
Posted By
Nobuddy
Crower "Cam Saver" is only for flat hydraulics. ...
Crower "Cam Saver" is only for flat hydraulics. It is a flat ground in the side of the lifter from the oil band to the face as a controlled leak for extra oil to the cam lobe/lifter face. So if you...
Forum:
THE LOBBY
12-19-2023, 11:53 PM
88
Potential Vintage Cat D7 Dozer Rescue - Have I Lost My Freaking Mind???
8,998
Posted By
Nobuddy
Has been a long time, but I believe you remove...
Has been a long time, but I believe you remove the cover on the top right side of the winch to access where the push/pull cables attach and are adjusted. I'm sure there is a manual for a D7D winch...
Forum:
Pontiac - Street
08-23-2023, 01:34 AM
398
Pontiac V8’s: Retrofitting GM Roller Lifters
71,143
Posted By
Nobuddy
Perhaps you could cut the Chevy bones and weld...
Perhaps you could cut the Chevy bones and weld with correct spacing? Seems much easier and avoids a lot of unknowns.
Barry
Forum:
THE LOBBY
07-14-2023, 01:36 AM
102
Small pick up trucks
5,853
Posted By
Nobuddy
Probably Tacoma's with frames from Dana corp. ...
Probably Tacoma's with frames from Dana corp. Made in America for what it's worth.
Forum:
Members Helping Members
06-23-2023, 01:55 PM
5
covering T-111 on a garage
594
Posted By
Nobuddy
Some kind of underlayment is required or you risk...
Some kind of underlayment is required or you risk rot in the T-111 from condensation. But probably not an actual vapor barrier like polyethylene sheet. Tyvek isn't a vapor barrier, it blocks air...
Forum:
Pontiac - Street
04-06-2023, 10:28 AM
57
Rod bolt - Torque verses Strech
3,440
Posted By
Nobuddy
Detroit Diesel peanut butter
Great stuff but don't use "peanut butter" for fastener lube unless you really know what you are doing.
Forum:
Industry Stuff
03-26-2023, 04:34 PM
25
Cam Shaft Core Shortage
7,066
Posted By
Nobuddy
Plus there is CWC, the foundry that manufacturers...
Plus there is CWC, the foundry that manufacturers the cast cores used by CMC. CWC is owned by Textron who is owned by Kautex. Kautex is global and does a lot of OEM work so I expect old Pontiac or...
Forum:
Pontiac - Street
03-23-2023, 04:43 PM
43
Fuel pump. Prime or gravity feed or ?
2,696
Posted By
Nobuddy
What kind of drugs do you folks take? Seems you...
What kind of drugs do you folks take? Seems you all like to argue about making a distinction without a difference. Just to be "right" or not recognize when you posted something ignorant.
Forum:
Pontiac - Street
02-02-2023, 02:42 PM
218
SpeedMaster CNC ported heads on sale
19,975
Posted By
Nobuddy
The Speedmaster set I have from two years ago...
The Speedmaster set I have from two years ago measured at 2.20" x 1.275" at the gasket surface and the openings are CNC cut as mentioned earlier.
Much like Edelbrocks, the RAIV (1233) type gaskets...
Forum:
Pontiac - Street
01-27-2023, 02:15 PM
122
Aftermarket Iron Pontiac head
9,118
Posted By
Nobuddy
I think there is a fantasy that iron heads would...
I think there is a fantasy that iron heads would somehow be less expensive even in the tiny volume of the Pontiac market.
Forum:
Pontiac - Street
01-27-2023, 02:00 PM
122
9,118
Posted By
Nobuddy
$800 per pair bare is ridiculously low. If US...
$800 per pair bare is ridiculously low. If US made anyway. Small block Chevy World S/R or Dart Iron Eagle are around $500 each.
Forum:
Pontiac - Street
09-13-2022, 03:04 PM
30
Performance 15" Tires
3,074
Posted By
Nobuddy
Maybe not easy to find at the local stores but...
Maybe not easy to find at the local stores but Michelin does still produce their classic XWX. I believe 205, 215 and 225 widths in 70 section 15 inch are all available. Blackwall only of course.
Forum:
Pontiac - Street
07-01-2022, 01:40 PM
81
Octane vs. ethanol
6,982
Posted By
Nobuddy
It is a different discussion so probably best you...
It is a different discussion so probably best you not add more misinformation based on popular legend.
There are no subsidies to farmers for growing corn for ethanol. Virtually all US farmers...
Forum:
Pontiac - Race
06-10-2022, 09:42 PM
12
.050 rod bearing for 2.20 journals?
1,764
Posted By
Nobuddy
King lists these for Pontiacs - CR 815CP 050 and...
King lists these for Pontiacs - CR 815CP 050 and CR 815CP 060. I have no experience with these but it seems they should work.
Forum:
THE LOBBY
03-17-2022, 01:29 AM
29
She's still magnificent!
3,599
Posted By
Nobuddy
I heard she is absolutely covered with asbestos...
I heard she is absolutely covered with asbestos in all interior spaces.
Forum:
THE LOBBY
12-12-2021, 11:40 AM
23
Michael Nesmith of the Monkees Passed Away Today
3,144
Posted By
Nobuddy
Peter Tork was also a "real musician".
Forum:
77-81 Firebird & Trans Am TECH
11-22-2021, 10:36 PM
72
I Miss Recaro Seats!
12,657
Posted By
Nobuddy
Like Gator67 said, these seem close if the budget...
Like Gator67 said, these seem close if the budget allows it. https://www.recaro-automotive.com/us/classic/recaro-classic-lx
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
08:32 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
