-   Pontiac - Race (https://forums.maxperformanceinc.com/forums/forumdisplay.php?f=419)
-   -   Spark plug recommendation (https://forums.maxperformanceinc.com/forums/showthread.php?t=857795)
RBAILEY 04-04-2022 09:51 PM
What spark plugs do you guys recommend I'm running Kauffman High ports with 74cc Chambers. Just need a part number so I can go down and pick up some plugs. Just need a baseline plug to start with...I plan on racing end of this month...temps will likely be in the high 80s liw 90s. It's my first set of aluminum heads and so I just thought I'd ask you guys what you running for spark plugs on Kaufman High ports.
Dragncar 04-05-2022 12:17 AM
Here are a few.
https://forums.maxperformanceinc.com...d.php?t=851232
bluegoat65 04-05-2022 09:13 AM
NGK R5672A-8 Projected tip. NA motor.
421 Bird 04-05-2022 02:42 PM
I have a set of the 56cc High Ports on my engine. Kauffman built the engine and they came with the NGK 5671A-9 plugs. I have continued using the same plugs.
Dave Polichena 04-06-2022 12:18 PM
I run the -9 plugs as well
RBAILEY 04-07-2022 01:55 PM
Thanks everyone .. I went with the NGK R5672A-8
