The foam around the instrument area on mine had too much foam and makes it difficult to install the instrument bezel.
The stereo area is the same way, had troubles installing the bezel.
The top leading edge is also wavy and is so tight against the frame some areas look like the frame may pop through.
The area where the lap/column cover is, is kind of puffy and not very 'square' to have an even gap around the cover.
Some of the corners are not shaped properly.
These areas are the same on my 70-72 A-body and the F-body dashes. So maybe it the process?
Both still look better than the cracked up and faded ones that were on there before, but for the money, one would think they should be near perfect.
