Since this will be more of street ride now I'll post here. Have a set of MT covers or these.
These are beginning to look more Chebby to me?? Is it just me?😕
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. ![]() Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
That engine and engine compartment looks beautiful to me
Working on it.
Those look like Cal Custom covers. Like mine.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. ![]() |
Looks like a pontiac to me. Finned covers were always a popular addition on every engine made. I think it looks just fine.
Classic Pontiac look right there.. Polish and go with them!!!
Troy, They look like Cal Custom valve covers. I know your a dual carb guy but to me a 60 looks more at home with a tri power. Arapaho is a great car, glad you kept it.
I'm an M/T guy, but try both, see what you like better!
I like them to. Right now I'm using stock valve covers with a 1" spacer. I found DCI has a 4" tall cast alum. in the shape of the stock valve cover that look good chromed. I will check into those.
60man, those are def Cal Customs. Anyone know where I can source correct breathers for a pair?
Personally, I don't like the 50's period, hotrod-look valve covers on 60's-70's musclecars. It seems like a step backwards.
Guess I'll hang with the Cal Customs for a while...Looks good with supporting cast in place.....and they clear the Poly-Locs..
I hear ya Bob Jones on the Tri-power......But I sold all my Tri-power stuff... But bigger motors need the quads... ![]() ![]() ![]() I found some breather extensions to use. I don't like the the oil drips on the finned covers... ![]() Hope this motor will pull some 13's... ![]()
Very nice !
SEVEN UPS 2.0 TAKING THE THIRD DEGREE ONE STEP FURTHER 2016 1/8 MILE 7.0 @ 100 MPH 406 B&M MINI BLOWER |
Looking good Mr. Jones...
Thanks Troy
You recon you can get that thing to run? ![]()
Troy, That pic you posted today looks much better with the carbs installed. What long branch exhaust manifolds did you use and is that the angled oil filter adapter.
Hope to David. It'll never see 10's again though.
Ill be happy with mid 13's ![]()
![]() Quote:
Long branches and angle filter adapter are factory stuff. Going 2.5" all the way back. 3" would be tight. Had them forever.
I like my Micky Thompson Valve covers. They to are painted like you have your Cal Cutomes are. When first paainted & the blue is nice & bright they loook greate, right now mine need a little touch up. I'm going to 2, $'s also this year & when I get ready to put it up for teh winter of 15-/16 I'm going to install Fuel Injection.
![]() Quote:
