Old 03-30-2024, 02:10 PM
form74's Avatar
form74 form74 is offline
Default Ram Air manifolds were powdered coating including the flanges
Should I remove the powder coating off the flanges before putting them on the the heads are with the gaskets be good enough they seem pretty flush, but I don’t want to leak either
74 Formula
Below motor destroyed last fall
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
New motor
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Results will be posted after the track
Old 03-31-2024, 08:07 AM
Red80TA Red80TA is offline
I'd run a file across it all just to may flat, even if coating remains. The powdercoating can have a slight texture and waviness that doesn't seal in all situations.
Old 04-19-2024, 04:38 PM
gman005's Avatar
gman005 gman005 is offline
Use the remflex gaskets Gary and you will be fine.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 04-26-2024, 02:11 PM
400 4spd.'s Avatar
X2. I started using them more than 20 years ago.
