Old 05-05-2019, 02:19 PM
92GTA's Avatar
92GTA 92GTA is offline
Default Fuel pump inlet?
I'm looking to put a fuel filter before my fuel pump.
Can anyone tell from the attached pic, which of the two SS braided lines is the inlet to the pump?
Thanks!
1969 Pontiac Firebird
Old 05-05-2019, 03:00 PM
The one on the right.
Bill Nye.
Old 05-05-2019, 03:02 PM
92GTA's Avatar
The one with the worst hose clamp job I've ever seen, haha! Going on 3 years now correcting small stuff from the previous owner, never seems to end.
Thanks a lot!
Old 05-05-2019, 03:51 PM
tom s tom s is offline
The one thats NOT going to the carb!LOL
Old 05-05-2019, 03:53 PM
92GTA's Avatar
Haha, good one. Shouldn't own a car if I couldn't figure that one out
Old 05-06-2019, 07:45 AM
Just as an FYI, it is not recommended to put a filter prior to a mech fuel pump, those things 'pull', and can effect flow.
Mech fuel pumps struggle as it is with a decent engine, adding a filter before the pump will make it worse.
Old 05-06-2019, 07:52 AM
X2, do not place a fuel filter in between the tank and the pump if that's the only pump on the car!
If the motor still has the stock Q-jet on it then the long paper filter is fine up to about 400 hp with a pump like most stockers that output 6 psi.
If your Carb is flooding out and your finding little black spec's holding the neddle open then it's time to replace all the rubber hose on the car as its breaking down.
Old 05-06-2019, 09:06 AM
How old is he braided line?
Old 05-06-2019, 09:41 AM
"QUICK-SILVER" "QUICK-SILVER" is online now
The one hanging lower on the left is IN.
High on the right is return.
Solid line going up to the carb.
Clay
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 05-06-2019, 11:21 AM
92GTA's Avatar
The braided line is from 2015.
Sounds like I'll just leave the filter where it is before my carbs fuel rail.
Thanks!
Old 05-06-2019, 08:13 PM
Clay
You know....I didnt look at it long enough! You are correct,
Bill Nye.
Old 05-07-2019, 07:22 AM
Thanks!
That braided line should be fine for like 8-10 years, should be good in that respect. May want to look at the rubber line under the car, if it hasn't been changed, that's a good sunny Saturday afternoon project.
