I'd love to see the dyno sheet on the 2 428's that you mentioned
Sent from my iPhone using Tapatalk |
My '67 400 is in the machine shop right now getting turned into a 433. I'm swapping the 670s out for SD Performance 260+ ported #48s. I intend on running the same Lunati 231/239 roller and will be using the Qjet and iron intake, at least for a good while. If I can approach or crack 500hp I'll be content. I intend on driving this car, not trailering or garage queening it.
I have a set of Doug's headers and an 11-bolt timing cover. Sounds like we're building similar engines but I don't wish to go any bigger in the cam department. I have a manual too and I want decent low end and cruising ability when I get an OD trans eventually. |
Karl |
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
I guess I may be different than most here, but if I were doing a short(er) stroke engine, I would be looking at higher RPM power bands, and it would have to have aluminum heads due to flow requirements.
Because of the higher RPM, it would have to be a solid roller too. HYD rollers usually give up around 6k, some of the short travel ones maybe 6500-6700, so you would generally cam it for lower RPM ranges with a HR. Granted, I have heard of folks going higher in RPM with HRs, but feel if you're going to 'do it', might as well just use solid rollers. Spray would be fun, but maybe not so practical. Traction is tough as it is, but you could always hit it in 2nd gear. I did a bunch of homework a few years ago regarding which suppliers of kits were better, and at that time, for an off the shelf system, chose NX stuff. Their' pickups, valves, sols, and plates seemed to be much better than most. With spray, I think it would be more appropriate to use a standard ring pack, maybe even choose a piston with a lower top ring, and set it up to accept up to 300 shot. Not that you would use that much, but it gives a safety margin, and room to grow. And without a doubt, would use MLS type head gaskets. I'm on board with the single plane (T2) and a square bore carb too. With a properly prepared short block, you can move your redline to like 7500-8200 and let it eat, shift at like 72-7600, and run some gear. .
Very mild cam with good vacuum for the power disc brakes on my Catalina. You asked about the cam gear, I like to use Scott Simms' needle thrust bearing setup, he sells it complete with a Rollmaster double chain with full adjustability for degreeing the cam in. Paul Carter did the machine work. DSC_0158_zpseuowy2nq by John Cogger, on Flickr dyno_data_zpsnvm5frsm by John Cogger, on Flickr Graph_zpsax7qwwk9 (1) by John Cogger, on Flickr
1964 Catalina 2+2 4sp, 421 Tri-power 1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM, Holley EFI, DIS ignition. 1969 GTO 467, Edelbrock 325 CFM, Terminator EFI 1969 Firebird Convertible |
Here is the 413 build. http://forums.maxperformanceinc.com/...d.php?t=785341 http://forums.maxperformanceinc.com/...d.php?t=795059 Here is the 422 build. http://forums.maxperformanceinc.com/...d.php?t=801783
I like that estimate.
Do you have a picture of the lifter bore oiling mod? Should I do it to this block?
You probably will not run 11's naturally aspirated, but it should be easy (with traction) with a small shot of nitrous. I actually got mine into the 10's.
Here you go. Just use a 1/4 ball burr on a die grinder, and carefully start about 1/4" below the oil hole, and grind straight up to the oil hole. If you use air die grinder, wrap a rag under the throttle lever so you have control of the throttle. Take it easy, and you should be OK.
Do you guys realize what it takes to MAKE HP at 7500?I dont mean just take a engine there but make power there.It takes serious $$$$s to get it there in the topend alone.Tom
Tom maybe a 302 Z28 motor Even my RAIV 400 with just some mild porting and a big solid did not want to go that high.
My little over cammed brodix head 11:1 350 sbc I had in my nova would buzz right there and past.....and I built it when I was 19 in a bedroom of a house
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
You shouldn't have posted this in the street section.
#38
I do
#39
There is a difference between making power there and just reving it up there.
#40
I thought you started making power at 8k, did you advance your RP cam?
