Odd Driveshaft
My 64 LeMans-
Has anyone seen a driveshaft that necks down like this? It’s about 3.75” in middle and at ends about 2.5” on both ends. While it was balanced by prior owner, the car has a driveline vibration during acceleration. I’ve adjusted my driveline angles and all is within spec. Don’t mind the leak - it’s long since been resolved. Could this odd design be contributing to the vibration?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt |
Yup looks like the driveshaft in my car right now. Had 1 built and still had vibration. stuffed that one in and
vibration was gone. Didn't even change the u joints. Maybe I just got lucky, not sure.
64 Lemans hardtop 4spd, buckets |
Sometimes on old shafts the welds at either end where the yokes go on have pin holes in them, this allows water to get in and rust up the driveshaft from the inside.
You then over time end up with a driveshaft that is out of balance due to thin tube walls in spots and the rust scale spinning around in there. Also take a good look at your shaft for missing tack welded on weights. You will see this as the remains of two tack weld dots where the weight use to be.. All this being said though if your only feeling a vibration under throttle then there is also something else going on!
The Following User Says Thank You to steve25 For This Useful Post: | ||
Chuck it.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
It could be a u-joint that's binding under acceleration. Or it could be a misalignment when the pinion angle changes under acceleration. It has to be something that changes when you accelerate. If a tire is out of balance it shakes at that speed under acceleration or cruise. |
Are you sure it's not a misfire or something else
It isn’t- definitely from the driveline. I will start from scratch on the driveline angle too.
On driveline angles, and maybe you already know this....
Typically on a street driven car you want the trans pointing 2-3 degrees downward, and the rearend pointing the opposite at 2-3 degrees upward. If drag racing there are other things to consider on rearend angles but I won't get into that here. Generally on an A-body 4 link you won't be able to change driveline angles unless you have adjustable control arms. Easier on a leaf spring car with angle shims at various degrees. On yours, if it's never been messed with back there you'll probably find the rearend is already pointing upward a degree or two at ride height. I've also found on many overdrive swaps such as the TKO's when using aftermarket cross members and/or aftermarket poly trans mounts the driveline angle changes quite a bit from where it would have been and some modifications are necessary to reacquire the angle you're looking for. |
The Following User Says Thank You to grivera For This Useful Post: | ||
I believe it is a length thing, as the shafts get longer they try to find ways to reduce the weight because my camaro driveshaft, which is shorter, is not tapered like this. The longer the shaft, the lighter it needs to be to reduce the whipping affect and increase the critical speed. It's why later on OEM went aluminum that you commonly see on trucks because those shafts are extremely long. Can't make a steel shaft that long unless you break it up with a carrier bearing somewhere in the middle. With that said, driveline companies can make an A-body steel shaft that is the same diameter throughout, as dad now runs one, however it's a much larger diameter and thicker wall tubing for more strength, good for 1000 hp. Larger diameter and thicker wall tube raises critical speed but the shaft also gets pretty heavy. Last edited by Formulajones; 04-18-2023 at 10:17 AM. |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
Yep - stock shaft.
You guys know why they made them like that? So they could re-use the same end yokes and not have to tool new ones. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
The Following User Says Thank You to Keith Seymore For This Useful Post: | ||
Lots of times I think most 68-72 A body shafts I have seen have the step.
Biggest difference in joints is how they are retained. 3r in the Chevelle and 1330 in the Camaro. Similar in size but one retained with injected plastic (replaced with snap rings) while the other does not. Last edited by Formulajones; 04-19-2023 at 07:12 AM. |
Put the rear up on jack stands and put it in gear. Watch the DS and the wheels. I chased a a vibration that I thought was just out of balance tires and ended up being slightly bent axles.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
I have a stepped driveshaft in my 65 Catalina. I question it’s originality though.
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
Been saying this forever, if the driveshaft is of unknown origin, or original to the car (and you bought the car new), then replace it.
You spend X on a driveline, and then cheap-out on a driveshaft? What sense does that make? How would you feel if it suddenly & randomly just failed? Uh-huh. Then the question you would be asking yourself is 'Why didn't I just go ahead and replace in the first place?' I've seen people chase a vibration and then in the end figure out it's the crappy old wheels on the car. Or crappy tires. Or the yoke on the differential and the u-joint isn't seated correctly. Or an old slip yoke/rear trans bushing. Just do it. .
The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
Guys spend tens of thousands of dollars on a vehicle build and then ask "hey - what should I be looking for in case I find a shaft laying beside the road?" K
That isn’t the case here - I have no issue buying parts but also diagnose in the process- it’s just the way I operate. Some “throw” parts at everything. I like to learn in the process.
When I get some time I plan to reconfirm the tailshaft and pinion angles then order a new 3.5” driveshaft.
