Hi Everyone, I've asked around on this one and I'm getting a lot of different opinions. Should you tighten down the Upper Control arm bolts with the weight of the car on the ground or up in the air? For that matter what about the lower control arm bushings? It's a 1966 GTO. I've rebuilt everything with stock parts and I'd like to know what to tighten and when. Up in the air, down on the ground, or does it matter?...Thanks!........Gary
tighten all the bushings , upper and lower , after its on the ground, after you let the car down on the ground move the car back and forward some. to settle the suspension then tighten all the bolts on the bushings
Thanks Everyone, On the ground it is!......Gary
U tighten all mounting bolts and and bring 4 bushing bolts just slightly loose then u tighten the 4 control arm bushing bolts with the suspension at normal ride height not! unloaded. This way the bushings are not distorted at ride height
DRIVE IT LIKE U STOLE IT! connman
connman |
tighten the bolts that hold the bushings with the weight on the suspension.
mike
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
I haven't gotten to that point on mine yet but. I think the proper thing is to snug them all up in the air (unloaded) but do your final torque tightening with the front end on the ground (loaded).
Hope this helps. A closed mouth gathers no feet.
The joker in the deck keeps sending me his card. Smiling friendly, he takes me in. Then breaks my back in a game I can't win. |
I bought a set of car ramps to make this easier.
I never try to drive up the things. Jack up the rear on stands close to ride height. Now you have car weight on front tires and can get to the lower bolts with the longer torque wrench. Mule Earschplittenloudenboomer [This message was edited by SJMule on June 15, 2003 at 12:18 PM.] |
Yep, thats right. Tighten when full weight is in place....
Take a ride in my Twin Turbo 63 Lemans....... http://www.youtube.com/watch?v=Ad8g9IfWxKI Hot Rod Cover Car -April '07 PHR Magazine Sept.'08 1244HP Pump Gas Dyno @ 11psi (32PSI MAX) http://s297.photobucket.com/albums/m...ipumpgas-2.flv |
