Which side is the header side of the Fel-Pro header gasket, or any gasket for that matter?
I suppose this question relates to the RAIII manifolds? I suggest no gasket.
I suggest the composite metal gasket even for manifolds - to act as a poor thermal path to relatively hotter manifold conducting back to the head. Probably better than that factory stamped steel gasket.
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
Actually, what I was initially referring to was the "Header Headaches" article in the Oct. 2000 HPP issue. Step 2 reads "Make sure you have the proper side against the header..." I am wondering if this is referring to the cut out gasket being positioned wrong if reversed, or there actually being a certain side of the gasket that should face the head side and the other the header side?
But this info about no gasket at all is new to me and a concensus of "gasket" to "no gasket" users might prove interesting. |
on headers i use gaskets and on manifolds i don't. it seems the manifolds leak quicker if a gasket is installed. mike
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
