Hi Guys! Hope you can help me out. I have a 1970 gto with a 400 c.i.d motor. When I restored it back in 1989 I put 455 frt. coil springs and stock coils in the rear.Ever since the car has been leaning to the left rear. I don't know if it is a defective spring or the mis match in the springs. I bought a set of helpers for the left spring and it help. Now I am replacing the shocks in the car and it is time to fix the leaning problem.Can somebody help me out.
Thanks guys for the info.I will replace the rear coil springs with varible springs.I hope this does the trick.Thanks again.
make sure the springs are seated in the proper location on the axle / control arms. if they aren't then a lean can occur. the front springs most generally cause the most difference. by shimming up the rear spring you may have just compensated for the front. mike
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
I had a problem similar that I thought was a rear spring.......turned out to be the FRONT on the opposing corner!
66 GTO, 69 Grand Prix The only thing I`m sure of...is that I`m not sure of anything! |
Will guys replaced the rear springs with cargo coils. The rear of the car sits higher,because the springs were a inch higher. Still have a problem. the front of the car sit higher and still leans to the left.I will replace the front springs and hope for the best. Keep you guys posted.
I see a lot of leaning A body cars. It could be from a tweaked frame but the springs are proably the problem. They put some pretty weak springs in the rear from the factory and a lot of times the back sits lower than the front. Rear springs are cheap in price, I would replace them first to see if it fixs problem.
I have A 69 Tempest that when purchased, was sagging badly in the rear. I replaced the springs in back with A new set of stock springs and it sat square at first, then after A couple days leaned to the passenger side. I replaced them again (no charge for these) with variable-rate springs (wagon application) and it sat square and now - 4 years later - still does.
* No mister, it just looks like A GTO, but thanks. * |
