Old 10-18-2008, 10:27 AM
500plus's Avatar
500plus 500plus is offline
Default Pro Products balancer seperated!!!
We I WAS going to go to the track last night...but while getting ready to strap down the car, I heard a knocking sound up fornt and looked and the outer ring of my new balancer was wobbling. It is the 90020 sfi balancer and the outer ring has completely seperated from the hub!! Just glad it didn't happen @ the track. Oh well still had fun with a friends car...he went from 11.8 to 11.43 with just a fuel pump and line change!!! Next will be a bigger carb.. Bill
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Any pics?
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 10-18-2008, 10:34 AM
Ron Genovese's Avatar
Ron Genovese Ron Genovese is offline
I had one and noticed one of the screws was missing, when I checked all the rest they were all loose. I got a replacement screw and locktighted them all. I used it for a while, but swiched back over to the ATI.
66 GTO
Old 10-18-2008, 10:39 AM
Jagtec1's Avatar
I have the PP SFI balancer, and check the screws regularly. I have not found them loose yet, but will inspect it more closely from now on.
Darin
9.81 @ 136.39MPH
Old 10-18-2008, 11:29 AM
I am a big fan of ATI and TCI Balancers. Never had an issue with either one.
Old 10-18-2008, 11:47 AM
500plus's Avatar
Does anyone know if the ATI 917160 has a 3 or 4 bolt pulley setup? I am reading it as a 3 bolt chevy style.
Old 10-18-2008, 12:04 PM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
Mine is 3 bolt. I was able to slot one hole in my stock pulley just a slight amount, then mark he other 2 holes from behind the damper, and then drilled those 2 new holes.
The pulley gets centered on the register. Easy mod.
Old 10-18-2008, 11:58 AM
KO KO is offline
Very common, don't skimp on balancers. Buy a good one, ATI, Fluidampr, Innovators West are some.
1989 Automotive Hall of Fame Inductee
Old 10-18-2008, 12:17 PM
tempest455's Avatar
tempest455 tempest455 is offline
ATI is 3 bolt. Just get a chevy crank pulley and open the center hole to the Pontiac dimension.
Tempest455
Old 10-18-2008, 12:37 PM
RARE can drill their aluminum pulleys for 3 and 4 holes.
Old 10-18-2008, 12:44 PM
goquick's Avatar
goquick goquick is offline
But we shouldn't have to get new pulleys or drill our pulleys to fit a Damper. We pay more $ for them because they are listed for a Pontiac, not a chevybb, so that extra money should be it fits our stuff money! One other thing is the Pontiac doesn't need as much material removed to fit as the bbc, so that's less machining time. But we still are charged more. I say they make it fit, and fit our pulleys, or they don't need to make 'em at all.
Old 10-18-2008, 12:46 PM
70 lucerne lemans's Avatar
70 lucerne lemans 70 lucerne lemans is offline
I have over 200 passes on my Proproducts balancer with no issues,after saying that I'm going out to check it over!
Mark
1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD....
1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs
(1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor
[email protected] on 150 shot
Old 10-18-2008, 07:00 PM
John Bailey (GTOKID)'s Avatar
John Bailey (GTOKID) John Bailey (GTOKID) is offline
Default ATI
x2 My ATI blancer is 10 yrs old...no trouble
Old 10-18-2008, 02:12 PM
500plus's Avatar
Well I have no problems drilling the crank pulley, I had to for the blower hub, so what the heck will some more holes be...think of it as "lightening"!!!!! I guess that jegs will get my money this time...they have an ATI in stock...unless anyone cen tell me if a fluid dampener is better. Thanks for the input....definitely disappointed in the pro-products brand. Bill
Old 10-18-2008, 02:35 PM
440GP69's Avatar
440GP69 440GP69 is offline
Summit sfi ballancer!!!! Awesome piece 100% bolt on, made by a ex Top Fuel Racer, uses STOCK 4-bolt pattern like BHJ except the Outer ring doesn't move, Butler used one on their 467 Engine masters challenge engine, good piece 230$ better than the PP by far
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 10-18-2008, 02:40 PM
I am trying to get the Vortech People to design a Crank Pulley for both the S/C set-ups that can use the 3 bolt chebby type Pontiac Balancer. This combination would replace the weak 6 bolt factory early Pontiac multi-piece balancers when using the S/C kits.
The 4 bolt stuff fits great as many people saw at the Norwalk event.
Tom V
Old 10-19-2008, 07:31 PM
LMSRACER's Avatar
LMSRACER LMSRACER is offline
Default Crap !!
I Agree with Tom V.
I've been Building Performance Engine for 20 Years...I've Learned to thoroughly inspect the Parts offered by the Various Manufacturers and Draw My Own Conclusions..
My First Experience with Professional Products was about 5 Years Ago..
I was Building a 302 Ford for a 66 Mustang and the Customer was Running Short on Funds..The Price was Attractive, so I Considered Using their Dual Plane Intake Manifold..
" What a Huge Piece of Crap ".. Out of the Box & Right Back in the Box..
What Did I Learn about Professional Products: Cost is the Primary Concern and Quality is Far down on the List of Priorities..
I've Inspected more of Their Products Since & Still Not Impressed..
As Far as Summit Products..Don't Buy any of Their Anodized Fittings..
The Swivel Fittings that I've Tried Leaked Immediately..
( No Wonder They Swivel So Easily.)
" Be Careful ".... Some on This Board will Sell Anything...
JMO..."Professional Opinion"
Larry Snyder..
( Certified Master Technician, Certified Master Machinist, Certified Advanced Engine Performance Specialist.)
Old 11-26-2008, 10:28 PM
mikeb mikeb is offline
thats odd..... i just plumbed an entire fuel system using pretty much all summit fittings and didn't have one leak. I did get a defective 90 degree swivel fitting but just used jb weld on it until I could get another to replace it.
Another vote here for the summit balancer. Seems like a great piece.
Old 10-18-2008, 03:59 PM
tempest455's Avatar
If you are using a stock steel crank pulley, just spin it a drill it.
Tempest455
Old 10-18-2008, 04:54 PM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
My PP Balencer took out the timing cover on my last pass at PSN this year. Went to a romac. Only had about 15 runs.
John
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
