I've finally decided to change out the ST300 tranny in my 65 for a TH 350. Here is my checklist:
Tranny Torque Convertor New Dipstick Shiftworks conversion kit I like to have all my parts before I start a project. Anything else I'm going to need?
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
Just curious, why a TH350?
Because it is supposedly a direct bolt in. No moving the crossmember, no changing the tranny yoke, etc.
Now we know the rest of the story. Thank you for that tidbit.
Detent cable and brackets?
Yep, the kick down cable and bracket is the toughest part. I think Lokar makes a universal. When I made the same switch in my '66 years ago, I found a bracket and cable to use in the junkyard, can't remember from what.
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc. '02 Firebird, V6, auto '68 GTO Convertible, HO, 4spd, driver '66 LeMans Hardtop, 400, FI, A/C, 4L80E. '65 GTO Hardtop, restoration ongoing '64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue. http://www.gtoaco.com |
Shiftworks conversion kit , you do not need , reuse your trans. linkage and bend the shifter stop at the end 1/4' back for the extra gear . Did the same conversion in my 65 15 years ago still works great . Save your money .
Anything else I'm missing?
I'm not running a kick down on the car now (2x4 setup), is it something that I positively HAVE to have? If I want to have a 'passing gear', I can manually pull it down into 2nd gear.
I made this change out about 15 years ago on my '64. replaced the trans about 3 years ago. In retrospect, I should have gone iwth the 200r4 the second time around
I'm leaning in that direction too, Andre. After putting a TH400 in my Grand Prix, I'm hearing the 200R4 is a better fit - and - one more (overdrive) gear would be nice. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
What kind of dip stick you looking to get or have
Looking to get the TCI-743860. It claims it a universal dipstick for GM trannies.
No to auto's !!! 4 SPD. IT'S A MUSCLE CAR !!!!! WTF !!!!! MY GOD !
What if a musclecar owner happens to be disabled and can no longer drive a manual shift car? |
Exactly why I own an automatic!
Me too, I only have one leg, so it's pretty tough for me to drive a 4-speed, not to mention dangerous and illegal. "Automatic Drive Only" is stamped right on my driver's license .
Put in a BOP TH350 in my '66...no mods needed. Same driveshaft.
Resto almost done - 1966 GTO HDTP Tiger Gold (paint code 1-2), black vinyl top and interior, 389 tripower, 068 cam, TH-350/Hughes TC, RA manifolds, 2.5" Pypes exhaust, Scarebird Front Disc, Ralley II's, factory PS, PB, PW, PA, A/C, headrest option. |
The only other alternative is the car gets parked and sits for 25+ years (which is what happened in my dad's case). K
The 200r4 bolts up without an adapter, but the crossmember would have to move. I think by now they probably have an adapter so you don't have to move the cross member. (at leas I hope so, especially for a drop top) The better low gearing, and the overdrive at highway speed is the advantage.
The 200r4 isnt for big torque high hp engines, but would have been just fine behind my 325hp 64 GTO. I could be doing 70mph at 1900 rpm. :-( |
