Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
EFI parts locating
Hi guys.
Been putting together some parts and researching others to fit port EFI into the Firebird. This is in a 9:1+ cr, iron headed driver. The current plan is to run a Megasquirt 3. I will add the MS3Extra for the sequential function as well. Also going to go with the Victor EFI, as this is just a modified Torker. I know it will require the shorter PICO injectors and I am hoping to find a OEM source for something in the 35# range for now. I am thinking hood clearance with the ability to use a spacer for plenum volume. And possibly, not likely, a hat connected to a small charger. 75mm or so. The manifold will be topped with a 4150 progressive style throttle body. Was thinking Accufab. Short height, GM sensors and great reputation. Probably going to go COP, but the EDIS system is stupid simple and need to weight the benefit of the COP. And I have been in contact with Ollie regarding a crank trigger setup, I realize I'll need a bit of machining on my old front cover, but that's no biggie. I know I need a fuel pump, lines, regulator, power supply ect. So, that's on my build list. I will most likely modify or buy a tank with an internal pump. So here's the question. Where do you guys source your parts? I am looking for the best deals available of course, just curious who you guys like to deal with. I most likely will not boost this engine down the road, but this is the foundation for another build idea as I have a pile of turbos to play with. So what say you? Sound like a solid build plan? What if anything would you do differently? And where are the deals at? I am knee deep already and open to any and all suggestions! Dave
'68 Bird Vert, 455 , 6x-8, 1.5 HS, HEI, PPR TC-02-HF, TH400, 2500 Hughes, 2.56 8.2 (getting swapped for second gen with shorter gears) Fishing guide in the Washington state for Salmon, Steelhead and Sturgeon. Fish-On! |
I have bought parts from E-bay, P.Y forums. Remember Pick A Part is your friend.
The EDIS module will operate a COP ignition. If you LT1 coils be aware that the Car and truck coils are different. The only thing in common between the two is the mounting screw pattern on the valve cover. The coil mounts on the bracket are different the coil plug is bigger on the car coil. Check out the photos on E bay you will soon get an "eye" for the difference. I picked up a set of the truck coils at Pick A Part. complete with the coils, mounting bracket and as much of the wire harness as I could cut past the big gray plug.
Its ok to giggle and snicker, Dont laugh and point |
Thanks for the tip on the coils.
What brand are those valve covers of yours? Looks like a good foundation for the coil mounts. I had even toyed with the idea of modding a stock intake with some injector bungs. Just for fun of course as it would be severely limited for breathing. I have even looked at using a quadrajet base plate or holley for that matter, machining an upper with a filter mount and making an external iac. But for the effort, a store bought unit is just easier. Dave
I got the crank trigger setup from Ollie. Awesome part. Had it in a few days. Packaged great, and has the most detailed instructions for the install. Thanks again Ollie! I have not used mine yet, but it sure is purdy.
************************************* 463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO! |
Yeah, the carb thing is just a measure of being cheap. LOL
As far as the dist, I was thinking the same thing. I have already made a priming tool by spinning one down on a lathe. In fact, I could get tricky and thread the top so I would have a viton o-ringed, fabricated cap. I could then turn it as an assembly and make the parting line vanish. And that would be a cool, low profile part! I will just machine my front cover and tig up and voids left behind. Or mill a flat to mount a pointer to. Should be easy enough. For the fuel tank, as I need a new one, I was wondering if using a late model in tank pump and module would work. I know I need to check the ohms required by the float, but could easily adapt an earlier one if needed. Maybe one of the cheaper prefabbed units is more reasonable. Now I just need to pull out the card! Dave
The valve covers are the cast aluminum Pontiac produced by GM, with the cast "PONTIAC"
When I got the coils at Pick A Part I unbolted the valve covers and cut the coil harness as far past the big gray plug as I could. Took about two minutes per side. The photo of the coils show the difference between the truck coli and the car coils. The truck coil is on the right, you can also see the heat sink of the truck coil. The mounting tabs are different and the wire harness plug is smaller on the truck coils. I think using the Accufab throttle bodie is going to be easier than trying to adapt a carb. Using a carb you would have to figure out how to mount a throttle position sensor and the IAC. when using COP or EDIS there still need to be an oil pump drive. Rather than having the big HEI distributor taking up space back there I had the top cut off and fabricated a cap to go over the end.
Its ok to giggle and snicker, Dont laugh and point Last edited by Ollie; 04-13-2012 at 09:34 AM. |
thanks for the complement Chris.
I don't know how deep the fuel tank is on The 68. I am using a 4 th gen fuel pump module, the tank needs to be 9 inches deep. Also have a part number for the GM 0 to 90 ohm fuel level sender. The fitting is a Russell 644120, New design with the threaded locking collar.
Ollie,
does that module compress? If so, is that dimension the compressed height? I could easily "sump" or well the area where the module would sit and further enhance it's ability to capture fuel. Obviously talking about the bottom side of the tank. May look a bit funky though. Dave
Tryed to get a photo of the compressed height , hard to hold the module down one handed while holding a tape measure in one hand and taking a photo with the other. You could sump the if you had to. Yes, Bruce, or anyone else, I too would like to see photos of other in tank fuel pump modules. The 4th gen is the only one I am familiar with. Do you know if the fuel level sensor is 0 to 90 ohm? The Vettworks Located in Auburn WA.is where I purchased my 4th gen fuel pump module I purchased the pump module , with out the plumbing adapters. http://vetteworksonline.com/ Link to installing the 4th gen. fuel pump module. http://www.vetteworksonline.com/ls1_conversion_fuel.htm This is the link to Racetronix, They offer Direct replacement application specific fuel pumps. http://www.racetronix.com/ this link is to Racetronix Other fuel pump modules http://www.racetronix.biz/items.asp?...atus=0&Tp=&Bc= I was just over at this link reading about these modules They are for Buick Grand National cars they have a 90 ohm fuel level sender. Does not state how deep the tank is. Would also have to figure out a baffle
Its ok to giggle and snicker, Dont laugh and point Last edited by Ollie; 04-15-2012 at 10:08 AM. |
There are "non module" in tank pump/float assemblies on earlier efi gm cars/trucks that mount with the same lock ring setup used on carbed cars for fuel pick up and sending unit. Check your ring size and go visit your favorite used part places. Very easy to modify the pump height/float arm on those. Let me know if you want a few pics of what I'm describing.
Dont get too concerned about the pump being good or if TBI setup as there are other pumps new that will meet your fuel pressure/flow requirements that can easily be fitted. The float arm can also be shaped as needed. Pumps for these are usually much cheaper than the module type. Many of the module types are hard to get only a pump for it or very hard to change out just the pump. (without breaking something) You can of course baffle your tank internally if you want instead of adding a sump. On the high power end Aeromotive pumps can be installed in-tank and they also sell a really nice, well baffled fuel cell with your choice of A1000 or Eliminator pumps already installed. |
Dave
I converted our 83 S10 Blazer 4x4 carbed,distributor to an SFI with in tank pump. I switched to a larger tank from a newer S10 Blazer and it had a 55 pound pump with the same lock ring and Oring as early GMs. It also has the same 0-90 float.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Scored a set of LS truck coils today.
Still undecided on the fuel system as theres lots to think about. But I am really leaning towards the fifth gen pump. I can soon a mounting ring for it work put of a piece of pipe. And I'll probably skip the factory hold down ring in favor of something far simpler. But if I have some extra time, I may go for the gusto. BTW, Vaporworx has both the ring mounted on a stainless plate and available separately. I figured mild steel would be easier to deal with than stainless however. And finally, really on the fence about the intake choice. I like the idea of the edelbrock victor and it's angled injectors. I don't like that I am forced to use pico injectors. I am still trying to determine what if any injectors are a direct swap and would do well at around 60psi. LS3 maybe? So, I need to order my tank and get this process started. Dave
Ollie, do you know if the coil on plug systems or coil pack type are CD or inductive discharge? I like the much longer spark duration an inductive system can provide in non distributor applications.
A single coil system.
COP are inductive in all cases I have seen.
Street/strip 1969 TA clone. Back halfed. 3300lbs. Twin turbo LSX 387cu. JW glide. Holley Dominator EFI. E85. Street driven. https://www.facebook.com/photo.php?f...type=1&theater |
Thanks Ollie... pretty sure the two I have are 90 ohm.. I'll check and get some pics while I'm at it. The look identical but 1 came from a v6 tb setup S10 and the other out of a 350 powered late 80's 3/4 ton truck. Sometime this week I'll see what psi these pumps can make and attempts to see how much they flow. The pumps were functioning when pulled.
As far as EFI... I like the ignition of the Electromotive system but not to keen on their fuel software... Looks like MS3 I can pretty much = their ignition side and do better on fuel side and logging etc... I've been getting familiar with Tuner Studio software(nice and comprhendable) so... once I start doing my efi it will not overwhelm me. May just run my distributor ignition/Accel 300+375 stuff at first but do want the advantages of a distributorless inductive ignition over CD... I'll take good voltage with long spark duration over higher voltage short spark duration capacitor discharge anytime. |
i am running MS3 with COP LS truck coils. it works great.
i should probably put together a list of the parts i used, but i haven't yet. any questions just ask. i've done a couple motors with MS. on my Pontiac, i did use the green top 42# Bosch injectors. i have 527hp 462 CID and they feed it easy and it idles great. for fuel pump, i used tanksinc kit in stock tank. http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm it is quiet, and of course stock tank fits, well, like stock. it has walbro pump that is plenty for my motor. the aeromotive pump is huge flow and i have read a few instances of fuel boiling because it is pumping too much through the system and radiating too much heat back into the tank like a cauldron. have you come up with a crank trigger yet? i used a 36 tooth motorcycle sprocket with a tooth knocked out. it worked great, but it is in place of an AC pulley. i'd like to have AC next season so i need to come up with something else. a friend of mine can laser cut a stack of them for pretty cheap so we should talk about a design for them if you want to work together on that. for cam signal, i have an entire MSD distributor still in there with the VR sensor and modified tooth wheel. fortunately can't see the distributor very well back there, but i'd like to make a stub like Ollie did. i used Edelbrock throttlebody that looks like a carburetor. it's been a bit of a pain because of the IAC motor on it. i just never got it to work right with standard step algorithms, but the MSExtra closed loop idle has worked great. works particularly well with the fans kicking in and keeping a constant idle. innovate o2 sensor has worked great for me, and i also hid a gauge in my flip down ashtray which i like to be able to watch on some heavy foot stuff. i made my fuel rails out of extrusion. i think from Haas or something? i bent the ss tubes and fittings from mcmaster. Rigid 37 degree flare tool was a great investment. the flexible lines from chassis to motor and chassis to tank were push on type from summit. great stuff, handles the new junk gasoline well, and not real expensive. i tried to stay away from the look of the red and blue anodized stuff because too flashy, and it's less expensive that way. can see the blue flex lines in pic down by oil filter: http://img818.imageshack.us/img818/9759/photo7su.jpg keep your wiring clean, especially your grounds. life will be easier through your MS experience that way. i ended up using just one capacitor right at the alternator. it's a small one too. a great investment was a hobbylab scope to really see what was happening with all the electronics. it took a lot of guessing out. good luck and have fun. megasquirt is a huge project, but will learn a load if you don't already know the stuff. |
Hay Monkey haven't seen you post in a while. good to see you posting.
I have 36-1 trigger wheels for the Pontiac harmonic balancer. It is 7.10 inch in diameter, bolts to the back side of the balancer so the stock pulleys are retained with out having to off set the alternator, power steering pump and AC compressor, I recommend using the late model timing cover with out the timing tabs. For the timing tab I used a modified Ram Air Restorations timing tab. I have the trigger wheels for sale $60 shipped priority mail. Includes instructions to fabricate the sensor bracket and how to mount the trigger wheel. I am working on a 4-1 cam sensor I have CAD drawings I need to find a machine shop to do some CNC work. This distributor cover can use either a magnetic sensor or the Mallory Unilite OPTO sensor.
