Have a question about fuel filter or fuel pump?
Normally at the schrader valve you get a healthy dose of fuel. I press the needle in and get a dribble. I've heard the fuel pump come on momentarily but still a small amount of fuel at the valve. Is it possible the fuel filter could cause this? The pump is in the tank. I'm having someone else do the job and told him to replace the filter first and test it. He says its the pump and want to drop the tank from the get go. I'm leaning towards the filter first. Is that reasonable? Can the filter suddenly plug for a no start situation and the pump may be fine?
Genesis 6:13 Last edited by GP67; 07-05-2016 at 08:59 PM. Reason: Spelling |
changing the filter is a natural first step.
1994 Formula 535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200 Pontiac Powered 4th Gen Project Progress |
Yes changing the filter is usually the first step. But depending on the model you are dealing with, some fuel systems require 50 psi minimum to operate, (96 chev truck) won't run with less than 50 psi, so pump can run but not enough pressure to run system, poppet type injectors, they have a check ball at end of injector line and need the pressure to overcome the seat. Not sure what vehicle you are dealing with?? Filters don't usually cause no start issues.
64 Lemans hardtop 4spd, buckets |
Replace filter first--but--I expect either a pump failure, an internal rupture of the in-tank plumbing, a plugged strainer, or an electrical failure.
In-tank rubber hose must meet special standards for "submerged" use, and high-pressure. Some folks cheat by installing standard fuel hose. The hose can rupture creating a massive internal fuel leak, low pressure, low volume. A defective pulse dampener can do the same thing. Even the hose clamps on the hose can make a difference: sh!tty worm-gear clamps and the hose damage they cause, compared to proper fuel-injection hose clamps ![]() The strainer "sock" on an in-tank pump can plug. In any event, if the pump/sock/internal hose is replaced, the tank must be checked for grit and other contamination. The fuel pump should be supplied with adequate electrical power. OEM in-tank pumps often have corroded in-tank fuel pump wire harnesses. Replacement harnesses can be had for about $20. The external harness and fuel pump relay are also suspect. Check voltage as close to the pump as you can, and check fuel pump amperage draw, too. A professional should be testing the fuel pump amperage draw with an oscilloscope and a low-amps probe. The oscilloscope can show amperage draw for each individual bar of the armature, and with very little work, can show pump RPM. Knowing fuel pressure, voltage, amperage, and RPM is a big help in diagnosing fuel pump failure. |
What Schurkey said.
Depending on the age/miles of the pump, if there's a delivery issue, shotgun approach is to drop the tank and swap the pump, sock, line, & harness (filter too). Most do so to avoid additional hours for diagnosis. Most of the time all it does is confirm what's suspected anyway. A lot of replacement pumps come as an assembly, and have new hose, clamps, harness, etc already installed. Let's hope the shop knows to flush/rinse the tank since it's a pump swap. Might want to go ahead and swap the sender too, for the couple bucks, it good insurance, since the labor to drop the tank is already spent. .
What year/kind of car are we talking about? If it was a filter, the fuel would still come out the same pressure, but no volume. The pump is toast.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
The E-15 fuel (gas pump gasoline) at the pumps today will kill a 80s style EFI system pretty quickly. By the 90s the OEMs were protecting for the "Flex Fuel" requirement.
I had a 2001 Ranger and a 2003 Windstar both have pump issues within 3 months of each other. Both had no issues with the E10 fuel but the E-15 Fuel has killed them and a lot of other vehicles in the last 3-4 years. I would drop the tank as suggested and inspect everything if you have access to a couple of friends and a proper jack to lower/raise the tank. Tom V.
![]() Quote:
Very True. I ran E-10 for many years in the same vehicles that failed when the E-15 stuff was authorized.
It's an 04 grand am se. The mechanic is charging $175 and I'm buying the parts. I would do it but he has a lift so the $175 is worth it to me.
It's just strange how it all came about. The Passlock system locked up the pump according to the literature. Thats why I'm hesitant to say the pymps dead all of a sudden. I described the situation on the Other Pontiac Tech thread. Oh and I have checked every fuse and relay in all three fuse locations. Drivers side, passenger side and under the hood.
Genesis 6:13 |
![]() Quote:
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. Last edited by TedRamAirII; 07-06-2016 at 09:54 PM. |
WCI read up on the Passlock and it states it cuts the fuel to the injectors. This makes sense because it gives the impression the fuel pump is dead. I did the Passlock bypass with a resistor off the ignition to fool the security system. It didn't work.
Normally when it trips the security light flashes, wait ten minutes with the key in the on position and the security light goes out. Turn key to off and restart. Car runs. This time the wife went to start the car and the Sevice Engine Soon light came on and the securit light. The security light was solid not flashing which indicates a total lock out. (Not Service Engine Light or CEL). "Service Engine Soon. So, I cut the black and yellow wires as instructed and a 2200 resistor all tied to a terminal block which in turn goes to the BCM. Simple bypass. Didn't work so I put everything back to normal and crank the car. Security light was blinking. Goid I thought. Waited 10 minutes, tried to start the car and wouldn't start. The security light however went out. The only lights on with the car NOT running are the battery light the oil light and the "service engine soon" light. I think the Passlock security system is still malfunctioning and denying fuel. I have heard and read alot of horror stories about VAT, and Passlock systems. Especially when it comes to mechanics replacing everything from ignitions to crank sensors when they haven't a clue about the GM crap Security systems. The codes. I don't have an ODB2 scanner. The mechanic is going to do this job Saturday. I will be there to see each step. How can I bypass the fuel pump relay? I will do that tomorrow night if it is explained to me.
Genesis 6:13 Last edited by GP67; 07-06-2016 at 10:13 PM. Reason: Info |
Before getting in deep, you need a trouble code. With Passlock, it should be a B (body) code. I would get a code, and that will tell you what direction to start looking. When you turn the key on, the theft light should light, then off. A Scanner to show PID values is a must.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. Last edited by TedRamAirII; 07-06-2016 at 10:17 PM. |
Genesis 6:13 |
The key resistor is just one component in the passlock system. By-passing the key wont correct the problem if something else is wrong.
To by-pass the entire system you need to locate the relay that supplies power to the fuel system. It's part of the anti theft stuff not the normal relays that make the engine run. I do not have a component locator for the grand am, so can't help with where it's at. Google search on that. Once you find the relay: The ECM is suppose to ground the relay to turn it on. Ignition switch power and ECM ground are what trip the relay. If the relay is good, key on and a jumper to ground on the ECM wire should power up the fuel system. It's been a long time and I would have to do some digging to come up with details on this. Maybe someone else with more experience will chime in on this. Good luck...Don't buy a pump just yet. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
Fuel pump died again.
Anyone have an possible reason why this car is going through fuel pumps? I'm all ears. 2004 Pontiac Grand am SE 2.2L Thanks
Genesis 6:13 |
Crap in the tank?
Check all the emissions stuff like tank cap, vents, canisters, etc. One of those areas if not right might load the pump more than the pump can handle, or at least for any length of time. Final thought - crap replacement parts. Where did you get the last one? .
1. Did I miss this? WHAT VEHICLE is this?
2. I don't hear the fuel pumps on my vehicles. Be sure it's a pump problem, and not a hearing problem. 3. Both of my Luminas (92 and 93) have a pig-tail near the battery that is intended to "jump" the fuel pump electronics. Touching the pigtail to a power source turns on the fuel pump. 4. Both of my Luminas have undersized wiring courtesy of GM's irrational cost-cutting. GM used 16-gauge wire when industry-standard voltage drop vs. wire size vs. wire length call for 12-gauge. There's more than a volt lost on the + side, and about a volt lost on the ground side. The fuel pump runs on about two and a half volts under system voltage. Hateful. I don't think you've done enough diagnostic work to be worth dropping the tank...yet. |
![]() Quote:
Not sure how the Passlock System got involved.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. Last edited by TedRamAirII; 07-10-2016 at 10:13 AM. |
What really irks me about the whole thing is this.
10 times now I have banged the tank and the car starts. After reading it says the brushes are worn and banging the tank moves them so the pump runs. Looking at the pump I got which is an OEM part, I'm not buying into that. There is nothing I see that would cause the pump to start other than a loose electrical connection. It's the only thing that makes sense as far as banging on the tank. Just my 2 cents. If anyone has a different proven theory I'd be pleased to hear it.
Genesis 6:13 |
