Old 01-05-2022, 08:28 PM
CanAmT/AGTO CanAmT/AGTO is offline
Default Steering Column Interchange
I have located a tilt steering column from a 69 Chevelle will it fit into my 70 GTO?
It is local to me and would be convenient.
Thanks in advance!
I Bleed Arrowhead Red,
64 GTO 389 Tri Power 4spd Nocturne Blue Poly
70 GTO 400 4spd Palladium Silver
75 T/A 400 4spd Buccaneer Red
71 T/A 455 4spd Cameo White
01 T/A Bright Red 4L60E Ram Air WS6
02 TA Navy Blue Metallic 6 spd Ram Air WS6
Old 01-06-2022, 08:18 PM
pont3 pont3 is offline
Yes it will fit, however, make sure the column includes the ignition switch, (not the key cylinder lock mechanism), but the actual switch on the lower portion of the column. The non-tilt column switch won't work with a tilt. Otherwise, all connections will plug right in.
Old 01-07-2022, 09:27 AM
PONT3, I really appreciate the information.
Thanks Again
Larry
