Just dynoed my 350P 2.0 build and cant wait to get it in the Ventura!
584.5hp/523tq on 93 octane BUILD SPECS ,030 custom Autotec pistons Eagle 6.625" H beam rods Eagle 3.75" stroke cast crank 10.7 comp. Cranks 175lb Custom solid roller cam 244/[email protected]" .676/.670 lift 112LSA KRE D-port heads bought bare as cast Custom chamber and port work to maximize potential with the small 3.905 bores 2.055/1.625 valve also for best 3.905 bore power Victor intake manifold with tapered spacer (Fully ported Street Dominator produced a bit stronger curve below 5000 rpm but lower peak numbers...576hp/521tq) 950HP Holley carb 1 3/4 headers Started this build with a goal of 575hp/525tq on pump gas and a 10 sec Ventura (NA) in street trim. 2 boxes checked! Cmon spring!
Home of the 350 Pontiac that KICKED FULPER'S ASS! |
| The Following 5 Users Say Thank You to POS Racing For This Useful Post: | ||
Real real nice job!
That high level of torque is very much due to all that valve lift and the attendant amount of air mass it allows to pass through the intake tract and the average high level of port velocity that is made! Air flow and velocity go hand in hand in at least a 50/50 ratio! A whole bunch of folks on here would love to have there .060” over 428 making that much power! Once again that’s a sweet motor !
| The Following User Says Thank You to steve25 For This Useful Post: | ||
Which part of the whole Intake tract where you using for the minimum port area in your port speed calculations?
That was what I came up with for average port speed using formulas from PipeMax and SRH site. Min cross section was 2.26 at the pr pinch. I am sure the port speed was much higher there.
| The Following User Says Thank You to POS Racing For This Useful Post: | ||
Excellent job, truly an impressive effort.
Maybe the price of boat anchors will be climbing now....LOL
| The Following 4 Users Say Thank You to Sirrotica For This Useful Post: | ||
Great job! Nice build!
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
wish they made an off the shelf heads like this. I bet there would be more 350P out there if they did.
"KRE D-port heads bought bare as cast Custom chamber and port work to maximize potential with the small 3.905 bores"
1979 Firebird Trans Am 301/4spd (Now 428) 1977 Firebird Formula 400/Auto 2007 Grand Prix GXP 5.3L |
| The Following User Says Thank You to 74Grandville For This Useful Post: | ||
I agree 100% I think the 350P should not be so overlooked. My first stab at one made 380hp/425tq with mildly ported iron heads and a flat tappet cam. The nice flat curve made for a 12.40 street driven Ventura. Making some head & cam upgrades and that one is going in my son's Ventura
Very nice!
Congrats on the build/achievement! Where's your local track for testing? I know here in NJ, Atco is usually the first to open in mid March for T&T if weather cooperates...best of luck with whichever track you test at!
Question: how much would you estimate you've got in this build?
You know me, "Safety Forst" 68 GTO-Verdoro/Black/Black, what else was available in ‘68? Has to be longest resto in history. 69 GTO Vert-Liberty/Blue/White Top, 4spd, match #’s 68 Mustang FB-Green/Black (Bullitt) |
6500ish in parts..plus machine work on the short block....build has taken 2 yrs so that figure would be higher now. Couldnt even guess how much time I have in the port work, cam design etc
Can you post the dyno sheet for the fully ported street Dominator? Depending on gearing and convertor it is possible that that setup might run faster in the 1/4 mile. Stan
Here are the best pulls for a ported T2, the ported HSD, and a reworked Pro Products crosswind. Really think the PP intake will be the best street intake? Wishing I had spent more time with the PP but we had 5 intakes and 4 carbs along to test. Knew it was gonna be a long day and honestly was chasing numbers. Sigh. My wife wants to take it back with some customized spacers and see if the smaller intakes can be made better. 24 pulls now....I think its time to put it in the car and tune there! 73 Ventura. 3450lbs. Th350. 3.90 gears and 28" tire
Impressive! You may have started something here.
Impressive. I can't wait to see the in car results. Let us know
Will do. Hoping to be at Mason sometime in March
I sure hope so. The little 350P has been pretty much kicked to the curb.
Very true
Nicely done. So much for the canard that you can’t make horsepower with less than a 4.000 cylinder bore.
