so i changed starter ,battery and alternator after i drive for half hour or so and car will not start up until i wait 15 minutes only thing i did not change was voltage regulator. all wire connections are clean and tight. so whats next?
Fuel tank vapor lock maybe, try opening cap if it doesn't start again and see if that helps. I got a remote tank filter setup and after a fill up sometimes it'll spit a tad out the filter if I do say 30 minutes on a hot day, damn.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
Doe the engine turn over properly? New starter but the cables could be bad causing hot issue and slow crank?
Distributor advance seized in the advanced position making it hard to turn over when hot? Give us some more info to try and make a better diagnosis. Engine size, Battery size. Stock engine? Turn over find but won't fire?
64 Lemans hardtop 4spd, buckets |
Yep...HOW does it not start?
George
i did notice the cables do get hot. it is a stock 400 with no mods. it cranks maybe three times then nothing. i took the car today to have new mufflers put on and i told the guy not to shut it off until on lift. he called me like twenty minutes later after testing the system and said i had a bad battery so off to get new battery. the battery i tried before was fully charged out of my truck and did the same exact thing.so for 65 bucks i'll get a reconditioned battery. purchased many batteries from this place so they are good.
Cable connections are one of the last things people check. Remember there are TWO ends of each cable. Often times it is the engine end that is either dirty or has paint under it.
So it was loose cable, corroded cable, bad cable ground or just a low amp cell battery?
well just picked up my car and the exhaust sounds great he added a cross over pipe also. so tomorrow i will go get a battery and new cables and hope for the best. thanks and i will post later tomorrow
well new cables and battery problem solved .
Good to hear, not too financially damaging either.
Cables and connectors are usually the sleeping devil right in your face.
yes cheap fix for battery and cables. i did have a rebuilt starter and alternator that i switched out. the car sat for six months over the winter and started right up so i was not thinking battery for starting issues i guess i am losing my touch.
