Old 07-07-2004, 07:08 PM
cowdoc cowdoc is offline
I bought a 67 convert. about 2 months ago. I noticed that the rear leafs have 3 on each side along with the traction bar on the passenger side. I thought 67s were supposed to have a mono leaf. Any thoughts
Old 07-07-2004, 07:22 PM
Hammered's Avatar
Hammered Hammered is offline
To my knowledge, all '67s had mono leafs but people were converting to multi leaf even in the 1970s so your car was probably converted.
John
1967 Firebird Convertible Factory 400/4spd
Now 462/5spd Fuel Injected
http://1967firebird.atwebpages.com/
Old 07-08-2004, 06:54 PM
CHASE CHASE is offline
I HAVE A 67FIREBIRD IT ONLY HAS 1 SPRING AND 2 TRATION MASTERS IT IS A ORIGINAL 400 CAR
Old 07-08-2004, 11:15 PM
Donovan Donovan is offline
Sounds like Hotchkis leaf springs. They work with Mono perches but give you three leafs. Aftermarket in any case. Cool! Best of both setups. Just need the other traction arm.
______________________________
1968 Firebird Coupe - 3665 lbs.
350 HO
Long Branch Manifolds
TH350
3.23 open BP axle
PS, PDB and Deluxe interior
GPE Starter ... Small body HEI ... 2.5" Pypes w/X-pipe ... Ruggles Qjet
14.1 @ 99.1
Old 07-11-2004, 07:48 PM
When I said I had one traction bar, I should have said that I had a rear axle radius rod. I know that chevy put them on 67 z28 and 396 to help with wheel hop. Were they also used on firebirds?
Old 07-12-2004, 12:27 AM
DanC's Avatar
DanC DanC is offline
cowdoc,
Yes the '67 Firebirds had a single bar for all models except the 400 which had two, due to the single leaf spring and inline shocks.
In '68 Pontiac went to the multi leaf spring, stagered shocks, and eliminated the bar on the FB's.
DanC
1968 Firebird Convertable - my original HS car!
1978 Firebird Esprit "survior"
1930 Ford Model A Coupe .. (original)
1994 Buick .."TowMaster" ...woody wagon
Old 07-15-2004, 06:34 PM
bird412 bird412 is offline
The 67 Birds camewith the rods from the factory.All v-8 cars rceived a single bar on the passenger side.The 400 cars got one bar if it was an automatic and two bars were installed on four speed cars.All 67 Birds had mono leaf springs and inline shocks(both mounted on the sameside of the rear end housing).Hope this helps.Even the ram air automatic cas only got the one bar.
Old 07-15-2004, 09:31 PM
einstein's Avatar
einstein einstein is offline
From a previous post by Doug Hopkins...
Here is the information from page 4-4 of the 67 Firebird service manual.
Radius Rod Useage
V-8 2and4 bbl.auto.trans one on R.H. side
V-8 2and4 bbl.man. trans two rods used
6-cyl. 4-bbl. auto.trans one on R.H. side
6-cyl. 4-bbl. man. trans two rods used
6-cyl. 1-bbl. auto.trans none ****
6-cyl. 1-bbl. man. trans one on R.H. side
****one rod if 3.23 axle
Old 07-20-2004, 08:27 AM
breakneck88 breakneck88 is offline
I am glad you brought this up!!!! I just picked up a 67 326 convertable and i thought someone might have removed the left side trailing arm??? that is the weirdest setup i have ever seen!!!!
67 'Vertible Bird and an '85 T/A.
Old 07-20-2004, 09:32 AM
Kybird Kybird is offline
Another poosibility, I saw in the good old JC Whitney catalog that they offer a 3 leaf replacement for mono springs for 68-72 Nova.
Old 07-20-2004, 09:34 AM
possibility!, my mental spell check was turned off.
