Old 07-04-2003, 05:24 PM
boboh1 boboh1 is offline
Have the original clock in my 67 GTO and had the original clock mechanism serviced. Now when I put it back in(No easy task) and hooked it up it gains 10 minutes per day. Is there a way to fix this without taking it out again? How about an inline resistor? Thanks.
Old 07-04-2003, 10:42 PM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
My clock does that after i lube it. It will slow down after time. Just keep setting it back and eventually it will slow down .
Scott
If you always do what you always did
You always get what you always got
Old 07-08-2003, 11:17 AM
That's good to know. Thanks.
Old 07-11-2003, 05:02 AM
Cardo's Avatar
Cardo Cardo is offline
I know that 10 minutes a day is excessive, but the shop manual says that these clocks need to be reset (adjust the time) once a week anyway. Mine seems to gain about 30 to 40 minutes a week, and it was a NOS that i put in 5 years ago.
"Not knowing, I hesitate to respond."
Old 08-04-2003, 10:20 PM
jpaitala jpaitala is offline
Mine's the same way also...
It advances 5-10min's a day.
'69 GTO with 455
Old 08-06-2003, 06:56 PM
mikes67lemans mikes67lemans is offline
dont you wish your time clock at work was like this at the end of every day?
