Old 05-20-2003, 11:09 PM
GTOGary GTOGary is offline
Does anyone have a rule of thumb for the starter shims that go on top of the stock pontiac starter that bolts to the block? This paticular engine did not have a starter attached to it before we rebuilt it and I've replaced the flexplate with a new stock unit. How do I know if I've got too many or too little? Thanks Everyone!....Gary
Old 05-21-2003, 06:54 AM
6t7goat 6t7goat is offline
Gary I don't know if there is a rule of thumb for starter shims but I just removed mine ( 67 gto) and it had 2 shims. Your ear is probably you best tool here. Maybe start with 1 or 2 and take a good listen as you crank it. Maybe somebody else will know for sure. Good luck
Old 05-21-2003, 07:45 AM
Colorado_Goat's Avatar
Colorado_Goat Colorado_Goat is offline
Use a screwdriver to slide the starter shaft out to where it fully engages the flexplate. You should have about the thickness of a paper clip between the teeth. Shim it until you have that gap.
A bad day fishing beats any day working...and if you can drive your GTO to get there....all the better!
A bad day fishing beats any day working!
Old 05-21-2003, 07:58 AM
ctgross ctgross is offline
I too just had mine off my 66 and it has 2 shims of equal thickness.
CT Gross
"It's never too late to have a happy childhood"!
66 Blue GTO
CT Gross---66 GTO
"Its never too late to have a happy childhood"!
I told my dad I was going to stop raising hell, and he called me a quitter!
Old 05-21-2003, 08:45 AM
brian damian brian damian is offline
yep 2 shims.but the paper clip method is prefered
to measure.
Old 05-26-2003, 11:17 PM
Thanks Mike C, Colorado Goat,ct gross, and weak 64. Your help is appreciated!....Gary
