Old 10-26-2004, 09:08 PM
snides snides is offline
I'm ready to reinstall the frame on my 67 GTO Conv. I will be using p-s-t polygraphite bushings and have purchased new body bolts. I can't immagine having too much trouble but thought I might check with every one to see if anyone has "learned the hard way" what to do or what not to do.
Thanks,
Keith
Thanks,
Keith
Old 10-27-2004, 05:06 AM
cujo cujo is offline
One thing I read here on this forum is that you need to install your fuel and vapor lines before you put your body back on the frame if you are installing original one piece lines.
Old 10-27-2004, 08:54 AM
RayJ RayJ is offline
The third bolt back from the front is shorter than the rest. Ordinarily the new bolts supplied are all the same length. You will either have to reuse the old bolt or cut off the new one. See attached picture. Also, there are a couple of smaller holes in the frame that match up with holes in the body. These can be used to temporarily install two long thinner bolts from the lower side of the frame to use for alignment when mating the body to the frame. This minimizes moving the body around trying to line up with the body bolts. They can then be removed from the bottom when the body is lowered onto the frame.
Old 10-27-2004, 09:12 PM
dracowizard's Avatar
dracowizard dracowizard is offline
Ray....when you said there was different lenght bolts in the frame mounts...well one anyway....does that just apply to a 67 conv...or would that also be true on other models.I plan to do a 65 clone and would like to know this b4 i screw up! Thanks
Gotta Luv some old Muscle..
64 GTO Sedan Produced w/PwrSteering-PwrBrakes-AC-Padded Dash/Rally clock/ RemoteSideMirror
3sp&3:08/10 boltPosi-Pwr Windows-Pwr Antenna
Silvermist w/BlackVinyl Top
http://s161.photobucket.com/albums/t201/dracowizard/65/
Old 10-28-2004, 06:11 AM
David Jones's Avatar
Run a tap up into the weld nuts.
Old 10-28-2004, 07:24 AM
mrrat1 mrrat1 is offline
Make sure the body is sitting square on the frame, before you tighten down the body mounts. There is enough leeway to be off to one side or the other. My 2 cents worth.
Old 10-28-2004, 08:10 AM
DeWayne, I believe the frame is the same for 64-67. The frame on the convertible is the same except I believe it is boxed for additional support. I do know that the convertible uses the same body mounts and hardware.
Old 11-06-2004, 09:29 PM
I knew there would be things I didn't think of. Thanks for the replies.
