Old 01-07-2005, 06:01 AM
uneasyrider's Avatar
uneasyrider uneasyrider is offline
I have understood that the stock block is only good for around 700-800hp I guess I'm wondering if a 900hp+ stock Ponch would last more than a few passes? Would that cryo freeze thing need to be done to it first?
Uneasyrider
Uneasyrider
“To find yourself, think for yourself.”
― Socrates
“The unexamined life is not worth living.”
― Socrates
“Wise men speak because they have something to say; fools because they have to say something.”
― Plato
Old 01-07-2005, 07:27 PM
Does a front & rear engine mount plate keep the fractures away?
Old 01-07-2005, 10:41 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Half-Inch Stud:
Does a front & rear engine mount plate keep the fractures away? <HR></BLOCKQUOTE>
A conventional Pontiac engine block isn't designed to be a structural member in the chassis of the car. The plate is to locate the engine in the car for better torque transfer by eliminating the flex in the engine mounts. The cracks in the block are caused from the internal stresses of the torque transfer through the block. If I remember correctly Pontiac's generally fail through the lifter galley and split lengthwise down the block. Think of the engine block as a brittle pop can and you grab the ends and twist it when you floor it.
Uneasyrider
Uneasyrider
― Socrates
― Socrates
― Plato
Old 07-20-2012, 12:28 AM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Originally Posted by fastgoat View Post
Has anyone out there made 2 hp/cu in. with a stock block normally aspirated Pontiac on race gas? Or with an aftermarket block? Documented (dyno sheets)?
I good thread from 2005, where are we now?
Calvin Hill
Hill Performance
708-250-7420
Old 07-20-2012, 03:48 AM
john marcella john marcella is offline
Im 99hp past 2 per CID right now on the dyno and still have work to do, and i think its a P.O.S. so far
Old 07-20-2012, 05:47 AM
Calvin Hill
Hill Performance
708-250-7420
LOL, i didnt even notice the date of when this tread was started.
Old 07-20-2012, 08:44 AM
fastgoat fastgoat is offline
I made 889.4 with 445" - 1967 400 block with 990 crank and Wenzler Super Chiefs in 2004. That's 1.998. Went 5.45 @ 126 in eighth @2790#. I have dyno sheets and timeslip. Coincidentially, the heads and tunnel ram a I just listed the heads and tunnel ram in the parts section
Old 07-20-2012, 10:18 AM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
We made 860HP for 440 cubes with a stock block in 1982. It went 146mph in a 3450 lb car for back up calculations. This was with old chassis efficiency heavy wheels, tires, anladder bars heavy drums, cast iron heads, no flow bench. With just fuel we have today we would have gotten at least 880 for 2HP per cubic inch. This was a stock block and we shifted at 9600 RPM.
We used this same block and crank in Stacy's Grand Am until 2010.
The new RAV engine being done must be 2.9HP per cubic inch to be on top 2.7 to be competitive. With our existing ports 2.7 for this engine is very capable, we must work very hard to get 2.9. We will post this project as it happens.
I think a mild set of RAV heads on a stock block 400 is worth 2HP per cubic inch.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
www.ChemicalManagementIndiana.com
317-260-3486
Old 07-20-2012, 10:19 AM
vin63's Avatar
vin63 vin63 is offline
Originally Posted by uneasyrider View Post
I have understood that the stock block is only good for around 700-800hp. I guess I'm wondering if a 900hp+ stock Ponch would last more than a few passes?
It depends on the generation of block, how you machine it, and your tune. I routinely make ~1500 bhp and have run the same three factory blocks for the last 5 years. One gave up the ghost last year when we had a lean-out condition from a return poppet spring failure.
1963 Tempest Convertible
Pontiac-Powered Funny Car:
400 block, Littlefield 8-71 blower, Enderle injection,
custom blower intake, three-disc glide clutch, three-speed Lenco
Old 07-20-2012, 06:32 PM
Tim Corcoran's Avatar
The question was NA stock block on gasolene
Tim Corcoran
Old 07-20-2012, 09:00 PM
In 1971, my buddy Gordon, with "Diamond" RA-IV heads and a 366 Engine was CLOSE at 706 HP at 8500 rpm. He needed to make 732 hp to be at 2 hp per cubic inch. The engine had a tunnel ram and two 660 center squirters, but was NA on race gas.
Tom Vaught
ps Marcella in another thread made over 2 HP per cid with his 481 engine.
Old 07-20-2012, 09:02 PM
vin63's Avatar
Answering the question quoted. I have 30+ passes on the stock 400 block that is in the car now - same block we ran in '09 through this past Pontiac Heaven - this block has more than 10 sub 7.50 et runs in a 2800+ lbs car. Why wouldn't that have relevance to the question from uneasyrider? Not sure I follow.
Old 07-20-2012, 09:03 PM
Naturally Aspirated Engine, not a Boosted Engine?
Tom Vaught
Old 07-20-2012, 09:08 PM
vin63's Avatar
Tom Vaught
The question from uneasyrider was could a factory block hold up to 900+ bhp. Is there more stress on the block from 900+ bhp naturally aspirated vs. 900+ bhp supercharged? Not sure I understand...where in post #21 does uneasyrider specify naturally aspirated over boosted? My apologies if I missed it.
Old 07-20-2012, 09:41 PM
A supercharged motor at same power level has WAY WAY WAY more stress on the block because the blower takes power to drive, a lot of power to drive, as well as transferring a bunch of harmonics to the crank.
Old 07-20-2012, 10:04 PM
vin63's Avatar
That was kind of my point...
Old 07-20-2012, 11:38 PM
This is the ORIGINAL POSTERS (fastgoat's question). NATURALLY ASPIRATED.
Uneasyrider added a second question in the middle of the thread.
You answered Uneasyrider's part of the question but not the original question.
Tom Vaught
  #38
Old 07-21-2012, 12:03 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
I have a set of McCarty\BES ported CNC RA-V heads; according to the dyno sheet they made 660hp on a 535cid. Are you saying all I need to do is change the cam and increase the compression a bit in order to make 1070hp? I currently have 9.1 to 1, what would I need for a cam and compression ratio to hit over 1K hp?
  #39
Old 07-21-2012, 12:29 AM
pastry_chef's Avatar
If you can make peak HP above 7500 RPM, approaching 8000 RPM .. > 1000 HP *should* be possible with 11 to 1 compression.
Ideally I'd want around .950 lift at the valve. If your heads have the CSA and run around 450 CFM or better on a flowbench? and intake/carb to match requirements.
  #40
Old 07-21-2012, 12:39 AM
RAIV-Z's Avatar
Unfortunately they don’t flow anywhere near 450cfm, the intake at .950 lift peaks at 388cfm.
