Old 06-11-2004, 08:59 AM
trans am ed trans am ed is offline
does anyone still race a 4-speed,if so what kind
Old 06-11-2004, 09:56 AM
tom s tom s is offline
the most popular for high HP use is the Jerico.
Old 06-11-2004, 10:23 AM
6567GTO's Avatar
6567GTO 6567GTO is offline
I'm going to be using a M22 Supercase Muncie.
http://www.5speeds.com/case.html
_________________________
Sonny Barger
Old 06-11-2004, 10:34 AM
APACHE APACHE is offline
I race a clutch assisted Jerico DR4 with road race sliders and the standard H pattern Hurst shifter, Super duty 1350 yoke and 1350 series U joints with solid cross.
Ram adjustable long style clutch.
Reliving my old man's glory days: street racing his '62 Savoy 413 wedge Eastbound on Dempster Rd.....any takers?
Old 06-11-2004, 11:13 AM
Larry Navarro's Avatar
Occassional strip duty, BW-T10 screaming for mercy.
Power shifting!....pedal to the floor, fannin' the clutch, engine singing off the rev chip.
Its a blast!!!!
Old 06-12-2004, 08:40 AM
A.W.Dille A.W.Dille is offline
Well I run the least desirable of all four speeds, a Saginaw but have had good success with them. I'm also using a Centerforce single disc clutch. Launch around 4 grand and shift at 5600.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 06-12-2004, 07:15 PM
NW S/D's Avatar
NW S/D NW S/D is offline
I,ve got a Liberty slick shifted Hemi NP 833 4 speed that was in my Mopar bracket racer, Thinking about droping it into my 73 SD T/A just for fun. It held up to a 590fpt 440 in a 70 Cuda , think it will work behind my pontiac. Jeff
1973 Super Duty Trans Am 455SD, Auto,White/White, Best Et: 11.39 @118 on Drag Radials 3875#
Old 06-12-2004, 07:42 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Muncie M-22.Hint-Redline MT90 is GREAT stuff for manual trans shifts. -JimT
Old 06-12-2004, 09:25 PM
Tom McQueen Tom McQueen is offline
Im using a Liberty modified (to fit a GM) 'Hemi' A833 4 speed in my street GTO (70). Very soon (next month) Im going to switch to the new TKO 600 5 speed and the 4 speed will be for sale.
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
Old 06-13-2004, 06:02 AM
NW S/D's Avatar
Tom, I have a question about your 833, is it a alum. case? if so have any problems with countershaft case hole elongation? or have they been bushed ? As you have probley guessed mine is a alum case based on the old Direct Connection part. And it does have case wear that needs to be adderesed, bushed once before. any help or suggestions? Thanks Jeff.
Old 06-13-2004, 09:55 AM
Jeff, I worked with a guy named Paul at liberty when I ordered the 4 speed. For strength reasons he recommended the iron case and standard 2.65 first gear, so thats what I went with. I have only put about 5 total hours of running time on the trans so far (most of it with the rearend on jackstands) so I have yet to hit it hard.
Old 06-13-2004, 10:01 AM
NW S/D's Avatar
Tom, thanks , I do have a iron case to , it just weights a ton. I,ll have to get in touch with Liberty I guess,BTW I have had zero problems with this trans I don,t think it,ll ever break unlike those damm Muncies.
Old 06-13-2004, 10:39 AM
how much work has to done to put a hemi 4 speed in a f-body. would a cast case t-10 be as strong.
Old 06-13-2004, 12:32 PM
There are 2 major mods done to the 833 4 speed to get them to work in a GM application. The input shaft is custom cut to the correct length with the correct pilot bearing on the end. So you will need to use a 1 3/16" X 18 11" clutch disc. The other mod is a custom front bearing retainer that will fit correctly into a GM bellhousing and use a GM throwout bearing. You will need to re-drill 3 holes for the transmission mounting bolts and add a small tab made from .250" plate for the fourth mounting bolt (looking at the trans mounting surface its the bolt in the lower right). The trans mount is higher than a Muncie, so you need a spacer. This spacer doubles as an adapter so you can use a GM trans mount. The speedo drive is the same as a GM. You will need a 30 spline trans yoke put on your driveshaft.
Nothing to it.
Old 06-13-2004, 01:25 PM
NW S/D's Avatar
Tom interesting, mine uses a stock retainer with a hydraulic throwout bering. Must use a aftermarket belhousing (McLeoud Chev type) they have a removable ring in the hole that the retainer goes in. I do not belive the T10 would be as strong as the Hemi 833 especially after Liberty gears & sliders are used. Jeff
Old 06-15-2004, 07:29 AM
Junkyard Dog's Avatar
Seems like the new Tremec 600 is a better choice. It handles 600 ft lbs of torque and has a .62 overdrive to make your 3.90 gears seem like a 2.41 on the Interstate.
Badder than old King Kong
-Jim Croce
Old 06-15-2004, 10:43 AM
pchris pchris is offline
Super T-10 with the cast iron case is the ONLY way to go. I went through 2 super T-10's and rebuily one and split the case's on all 3. Have a 455 that would to the 1/4 in 13.00@107 spinning through 1st. About 480 HP. Got the iron case and no more problems.
Bottle or boost....help me decide!!
Old 06-15-2004, 10:42 PM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Doug Nash 4+1 Pro shift with straight cut SAE 9310 steel alloy gears and 3.25:1 first
Working on going faster (and now staying dry at the same time !!)
