Old 11-13-2004, 09:42 PM
bbutler bbutler is offline
I found a excellent set of American Racing wheels (17X9.5, 5.5" backspace). I know 9.5" wheels will fit on the back. Has anyone installed 9.5" wide wheels on the front of a early 2nd gen TA? It is a power steering car. What was the impact of 17 x 9.5 wheels on the ride and handling?
Thanks,
Brock
73 Trans Am
71 Porsche 911T Targa
68 Alfa Spider
76 BMW R90S
75 Yamaha XS650B
Thanks,
Brock
73 Trans Am
68 Alfa Spider
76 BMW R90S
75 Yamaha XS650B
Old 11-17-2004, 03:30 PM
joeljet joeljet is offline
sombody please answer him i was going to ask the same question. ar say they will but if you mount a tire they're sold
Old 11-17-2004, 09:33 PM
Young One79TA Young One79TA is offline
I'm pretty sure there will probably be some rubbing on the front sway bar with a rim that wide. Some people have rubbing problems when turning on 8" rims with bigger tires, especially when at full lock. But I'm not sure to what extent the rubbing will be as I haven't heard of anyone running anything bigger than 9" wide in the front.(They had some slight rubbing problems)
Old 11-18-2004, 08:35 AM
Beebe's Avatar
Beebe Beebe is offline
Brock, Do you plan on running any sort of traction device / Bars ? BE sure to have them mounted before checking for clearence.
I used to run Cragar 17 x 9 with 4.5" BS , yoko 275/40/17 tires. This sidwall would slightly rub the lakewood traction bar mount when cornering. So if you are running a 9.5 rim w 5.5 BS ,.......you May run into issues.
Also Known As "Beebe" on other sites....... PZ , Pro-Touring , Lateral-G, TAC
Old 11-18-2004, 09:37 PM
Nope - no bars. It sounds like 17 x 8" w/4" backspace is the way to go. I'm going to pass on the AR wheels.
Brock
73 Trans Am
68 Alfa Spider
76 BMW R90S
75 Yamaha XS650B
Old 11-19-2004, 05:07 PM
73ta's Avatar
73ta 73ta is offline
I'm running them on my ta. seem to fit just fine.
Old 11-20-2004, 06:41 PM
Are you running the 9.5" wide wheels? How is the handling and steering? What size tires?
Brock
73 Trans Am
68 Alfa Spider
76 BMW R90S
75 Yamaha XS650B
