Old 11-27-2004, 06:43 AM
PONTIAC DUDE's Avatar
I have a 76 Firebird with a 400 ps, a/c and the 'big' 100 amp Alternator. But seems to have alignment issues. Looks to be rigged by the previous owner. Does anyone have pics and part number's that are on the pulleys and brackets to get this back to stock. Also has some sort of adjustable idler located on the pass head to adjust the belt for the alt, ps or A/C ????
Old 11-27-2004, 10:07 AM
Held for Ransom's Avatar
Idler pulley is for the alternator belt. I believe the pulley numbers are, Crankshaft Pulley 481038 YB (for A/C) and 480509 XS (A/C belt pulley) and Water Pump Pulley 481040 XT. I only see a casting number on the aluminum piece 485991 (I have the complete set off a '73 motor).
So long, farewell.
Old 11-27-2004, 12:45 PM
Are you sure this is for a 76 Firebird with the larger size alternator?
The idler is the same.
The #30 bracket I have doesn't have the adjustment slot. It's a non adjustable bracket. Also missing the #13, but have seen one of those somewhere in my storage extra parts bin.
My #20 bracket is different too?
Old 11-27-2004, 01:50 PM
Formulafr's Avatar
Formulafr Formulafr is offline
Send a message via ICQ to Formulafr Send a message via AIM to Formulafr Send a message via Yahoo to Formulafr Send a message via Skype™ to Formulafr
i was thinking that the biggest alternator for our firebird was a 80amp.
like mine equiped with A/C and rear defrogger.
Old 11-27-2004, 02:22 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Formulafr:
like mine equiped with A/C and rear defrogger. <HR></BLOCKQUOTE>
Which kind of Frogs does it get ride of. Does it burn their little feeties or just shock them.
LOL.
Just kidding, dude.
I guess it's the 80 amp. Just that the brackets on the car are different then the pics he shows. Of course, that's probably the GM 'one size fits all' pic GM supplies.
Anyone have engine compartment pics?
Old 11-27-2004, 02:29 PM
Lady Dude's Avatar
Lady Dude Lady Dude is offline
Ah...hey guys...pay no attention to my husband. He hasn't been racing in a month an' he's gettin' cabin fever...LOL
If you think you've got everything under control...you're not going fast enough...Mario Andretti
Old 11-27-2004, 03:54 PM
OK, Ken. Do your brackets look like this? Of course, one bracket is missing, as well as all the bolts, spacers, alternator, etc. so I can't mock it up.
So long, farewell.
Old 11-27-2004, 04:33 PM
Thanks, looks like what I got. Just that the person that had this 76 I bought before me must have lost the spacers and had a bunch of washers where spacers should be. etc, etc.
No back brace for the alt. but then it had a performer intake and that bracket might not bolt to that manifold and he left it off.
I'll download the pics. Thanks again.
Need to check the pully #'s too as the washers might have had the pulley alignment off.
Old 11-28-2004, 05:28 AM
Formulafr's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by PONTIAC DUDE:
LOL.
Just kidding, dude.
<HR></BLOCKQUOTE>
sorry i didn't really understand what you sayed. (think it was a joke )
Old 11-28-2004, 11:20 AM
Formulafr, it was a joke. You had typed "rear defrogger" instead of rear defogger. And he really was asking if you had the blower motor type or the electric grid type.
So long, farewell.
Old 11-28-2004, 12:50 PM
The 1st pic Held for Ransom showed is the same stuff he shows in his other pic.
You will need that #30 bracket if you don't need it.
They mounted the alternator sideways instead of 'up and down'.
They were mostly on A/C cars with electric windows and the rear 'de-fogger'.
Old 11-28-2004, 01:49 PM
John. The pic #30 shows an adjustable alt bracket.
His personal stash shows the same bracket I got. Non adjustable.
Once the Big alternater is bolted in place there is no way it will move. Have the engine out and fixing a pan leak in the car when I bought it so When I go back together I will check to see if the idler will line up with the alt. It was in the trunk with the A/C parts & brackets.
The way I got the car the belt was around the crank/water pump and alt with no adjustment and a bit sloppy.
Old 11-28-2004, 06:27 PM
Ken. I assume you know the obvious, the idler bracket has the adjustment arc in it. As with the #30 bracket being incorrect, I also wonder if the #13 bracket is correctly pictured (if even needed).
So long, farewell.
Old 11-29-2004, 05:34 AM
Yes I assumed that the arc in the idler will be used to adjust the alt. Like I said, I have to get the engine back in the car. I noticed all this on dis-assembly and wanted to make sure I had all the pieces when I put it together. Didn't want to do it twice or wait 2 months to find parts and info. Thanks.
Old 12-05-2004, 11:57 AM
jotrout jotrout is offline
Held for Ranson
I'm looking for a set of brackets. Let me know if you have.
Joe
Old 12-05-2004, 12:07 PM
Joe, saw your other post on needing brackets. Are you looking for the 80 amp brackets or the '71-75 or '76 normal brackets/pulleys? This set I'm keeping for now, unless I have another set with the spacers and such. I will keep you in mind if I do find another set around here.
So long, farewell.
Old 12-05-2004, 06:53 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Pontiac Dude:
How come Lady Dude isn't doing her part to relieve some of that cabin fever that she claims you're suffering from?
I hold her directly responsible for your inability to control your smart a$$ comments about that dudes rear defrogger.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 12-06-2004, 03:17 AM
WHen both people race, then both have Cabin fever, LOL. hard for one to control the other.
Old 12-06-2004, 03:26 AM
Finally set the 400 back down in the chassis and got all the brackets and pulleys lined up.
Had all the brackets but the rear alt to manifold, but found one in my stash.
But no spacers to be found with the car.
I got a 75 Factory maunal with a 76 supplement and a CD disc with pics and info. But they only show the length for 2 and both are wrong for the 80 amp deal. At lease to line up my pulleys.
I think there are 4 spacers used? Does anyone have the overall length of these spacers and there location for future reference and to make sure I got them all?
BTW: the 76 Firebird 80 amp alt doesn't have the adjustable bracket shown in the pic, just a hole to lock it in place at that locqation. The idler does the adjustment. Thanks for the help.
